Author Subject: Speedo not working
daddy5times
As title speedo not working since I removed battery to get easier access to thermostat elbow I didn't unplug any wires so I'm a bit stumped any help appreciated
Posted 8th Aug 2011 at 17:21
Knocked the plug off the sensor or caught it and broke the wire?
  • Posted 8th Aug 2011 at 17:35
    daddy5times
    thx dan where's sensor???
    Posted 8th Aug 2011 at 17:43
    On top of the gearbox
  • Posted 8th Aug 2011 at 18:36
    daddy5times
    Isit a black plastic looking screwworm a White cap? Ifit is the cap looks a bit damaged is there meant to be a wire on it thanks
    Posted 8th Aug 2011 at 20:23
    daddy5times
    Not screw worm. plastic screw thing dodgy spelling cos I'm on a phone. Lol
    Posted 8th Aug 2011 at 20:24
    No, that's the oil filler.
    It's above where the driveshaft goes. You will have to look over and behind the gearbox.
  • Posted 8th Aug 2011 at 20:26
    daddy5times
    I know I seem a bit slow but I'm new to peugeots .does it have a cable coming from it ?going into bulkhead if so it seem ok
    Posted 8th Aug 2011 at 20:43
    gman
    That's the one!
    1992 Onyx Black 205 GTI-6
    2005 Honda S2000 (Sold)
    2002 Audi S3 (Sold)
    2005 Clio 182 Trophy (sold)
    Posted 8th Aug 2011 at 20:55
    daddy5times
    Cheers pal all looks ok there could it be a fuse????
    Posted 8th Aug 2011 at 20:57
    daddy5times
    Checked all fuss and they seem to be ok!?????
    Posted 8th Aug 2011 at 23:05
    ryangti6
    To be honest that sounds like the lift up reverse you are on about.
    If you look down the back where the linkages are to your left you should see a plug, it should have a cover around it so may have to slide that up the wire to actually see the plug.
    Ryan
    Posted 8th Aug 2011 at 23:17
    daddy5times
    Thx I'll have a look now
    Posted 9th Aug 2011 at 00:35
