displaying posts 1 to 2 of 2
Author Subject: oil leak onto flywheel
velar
I have a leak from the rear crank oil seal area. Replaced the rear seal, and still leaking.Angry Angry
I remember reading that the rear j seals on the big end cap can be troublesome, so looking for tips when I replace them.
I know this has been covered before, but can't find it.
Posted 4th Aug 2011 at 22:55
krisb
Did you change the guide bush seal whilst you were there?
Generally, the crank oil seal leaks more onto the rear off the fly and flicks off. If the guide bush seal it leaking then it runs along the gearbox input shaft straight into the middle of the clutch.
www.krisb.co.uk
Posted 4th Aug 2011 at 23:32
