Author Subject: Weird clunk
cwspellowe
HI fellas, thought i'd get a bit of feedback before I go replacing MORE parts.
I'm getting a clunk coming from the passenger side strut area under setting off and hard braking. I also get judder through the steering wheel under braking that is not present at any other time, only when braking. I'm also getting what would appear to be a bearing/CV type noise when turning right but a garage has confirmed the bearing and driveshaft are in good condition. The discs are also seated properly and confirmed not warped.
The judder is more of a wide side to side shake and can feel the car pulling slightly over rough ground, also getting a fair bit of torque steer under load.
Within the last 12 months its had:
New front discs + pads
New balljoints x 2
New hubs + bearings x 2
New top mounts + bearings x 2
New wishbones P-bushes and round bushes
Only think I haven't touched is the track rod ends. The tracking is definitely out, but the TRE's were replaced nearly two years ago with pattern parts. If one's not done up tightly enough or is worn, i've heard it can lead to all the symptoms i'm experiencing.
Thoughts?
Bye bye Sundance Kid Sad
Posted 29th Jul 2011 at 16:49
Is there any play in the wheel when it's yanked up? My TRE's were fine, but the end going inside the steering rack was knackered and making a clunk.
Doesn't sound like what you're experiencing, but worth checking in case.
New steering rack sorted it.
Posted 29th Jul 2011 at 16:54
cwspellowe
Dry Really rather hope it's not rack related.
The tracking seems to vary though when you look at the car front on. Some days the N/S wheel definitely has more toe than others. Almost definitely play in SOMETHING...
Posted 29th Jul 2011 at 16:55
Not a snapped bolt holding the wishbone in or something stupid? Would still look fine and probably wouldn't fall out as it's under load.
Posted 29th Jul 2011 at 16:58
cwspellowe
Blink
f*cking hope not!
Posted 29th Jul 2011 at 16:59
honestly3k
Sounds like same symptoms i had a couple months back. I just went under the car and torqued up ever nut and bolt i could find which cured it. Also had those issues when my wishbone bolt was really loose. Sounds like something could be loose down there
Posted 29th Jul 2011 at 17:06
russbez
iv had the small 13mm bolt snap in my p-bush once Sad
p-bush destroyed pretty quick and wasnt good for rest of bushes and track rod ends
or.... but if you havent replaced the track rod ends in a while id go for them.
Also check your Track Rods themselves ; where they meet the steering rack (hard as they have rubber covers you wont get off)
i had to replace mine a bit back, although that was more of a constant wobble which got worse when braking
My Rallye project thread
Posted 29th Jul 2011 at 19:45
Best bet is to actually take the bolts out of the wishboens and balljoints, then re-torque them all, can feel tight even if they've stripped/slipped or picked up on some muck, etc, so a spanner check just on the end doesn't really help.
Does sound like either a track rod or a wishbone moving though at first guess.
Posted 29th Jul 2011 at 19:47
iplay
Drop Link ... ftw! Whistle
Just had similar symptoms. Felt like the front steering/suspension was detached. This was caused by just one end of the right drop link being seized.
Also check the calliper to hub mounting bolts for the brakes ... and apply locking compound 120Nm i think.
Posted 29th Jul 2011 at 19:54
russbez
mind tightening your wishbone bushes while they have a load on them, i.e when car is down on 4 wheels
or as it says in faq section, i think you can jack the hub up, that way your rubber bushes wont perrish soo quick?
correct me if im wrong!
Posted 29th Jul 2011 at 19:56
cwspellowe
Hmm i'll just have to take everything apart again i think. Had it all stripped down when I fitted new top mounts, ball joints and bearings, the noise was present before that. Will pop to the motorfactors, TRE's aren't exactly expensive and mine look to be a bit seized
Posted 29th Jul 2011 at 23:21
bellcp306td
Have you checked if your gear box mount is tight?
Where did the road go!
Posted 1st Aug 2011 at 20:24
cwspellowe
Yup, tight as a nun's chuff Yes
Posted 3rd Aug 2011 at 01:01
monty-69
Check the anti roll bar u shaped clamps are located into the subframe slots. Have seen one wedged between subframe and car
Posted 3rd Aug 2011 at 03:37
beez_neez_gt
Which ball joints did you buy to replace the old ones ?
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 8th Sep 2011 at 13:14
