Author Subject: kaaz diff install isssue
velar
I have just installed a KAAZ diff on my be3 box. I cheacked that the diff did not foul on the gearbox casing, and I checked the bearings were in the same position as the diff I removed.
Is it normal to feel a lot of resistance when turning one ( or both drive shaft) or is some thing not right inside the diff/casing.
If I turn one wheel with both wheels off the ground, then the drag is quit considerable.
Posted 24th Jul 2011 at 00:55
Think thats just how they are ? can't really see how you fecked it up if you put it all together correctly ? I assume you have the correct diff oil in ?
Posted 24th Jul 2011 at 04:13
devere
I just put my BE3 box back in this afternoon after having it rebuilt in to a new case. Once i had the shafts in the hubs, i just went to spin it a little before going any further, and i couldnt turn it without a wheel on the hub.
Although that was before i put the oil in, so that may have added slightly. But aslong as it is all fitted properly, i wouldnt worry, its not like you are just spinning one side of an open diff.
Posted 24th Jul 2011 at 06:35
allanallen
Are you 100% that you ground enough material out of the casing? With both wheels off the floor and the car out of gear the wheels should spin fairly easily.
I assume you've fitted the original crownwheel onto the diff rather than a different one?
Al
Facebook
Posted 24th Jul 2011 at 11:52
devere
There arent any clearance issues with the Kaaz. Well, there werent on mine, unless the diff housing vary in any way.
Posted 24th Jul 2011 at 16:12
velar
Good to know, as I found no clearance issues either.
With both front wheels in the air, and the car out of gear, is there a fair amount of rolling resistance on one wheel?
Posted 24th Jul 2011 at 22:46
rallyeash
my mates diff won't allow one wheel to turn whilst in the air
309 3dr K20 Type R
Posted 24th Jul 2011 at 23:27
allanallen
Yes with just one wheel in the air you won't be able to turn the wheel very easily.
Have you driven it yet?
Bit OT but did I spy you at pugfest today ash? I was in the White 309 track car.
Facebook
Posted 25th Jul 2011 at 02:33
velar
With only 1 wheel in the air, I would expect the wheel to be difficult to turn, but should it also be difficult to turn one wheel with both wheels in the air.
haven't driven it yet though.
Posted 25th Jul 2011 at 04:01
rallyeash
yeah that was me, your 309 looked good, think i was either behind or infront of you a couple of times waiting to go up the hill
309 3dr K20 Type R
Posted 25th Jul 2011 at 15:37
cwspellowe
I'd have thought so, an LSD is designed to stop or limit the wheels turning at different speeds, so using a bit of logic trying to turn a wheel by hand would result in you effectively having to turn both wheels ie twice as hard as the standard diff. Ish. Turning one driveshaft by hand would be like the car trying to spin up a wheel with low or no grip, which the diff is designed to limit, so you're fighting the diff there.
My money's on yes, it's supposed to be like that.
Unless i'm talking absolute bo***cks. But it makes sense to me Laugh
Bye bye Sundance Kid Sad
Posted 26th Jul 2011 at 03:33
velar
The drag was there with only one drive shaft fitted.
Drove the car, and the diff has freed up a lot. Will be trying it in anger on Friday.
Posted 26th Jul 2011 at 15:02
rallyeash
this allways sorts everything.... Fact!
309 3dr K20 Type R
Posted 26th Jul 2011 at 15:05
velar
If in doubt take it outWhistle Whistle ( on track that is)
Hope to see how much quicker the car is around coombeWink
Posted 26th Jul 2011 at 16:08
