Author Subject: Airbag warning light
stevegti-6
Hi, After fitting an after market steering wheel I now want to get the airbag light to stop flashing. Does anyone know of a way to do it
(other than taking the bulb out of the dash)
Is it a case of connecting the two wires to create a circuit or can you get a specialist bit of wiring??
Posted 21st Jul 2011 at 19:16
You need to wire a resistor in, but I don't think anyone ever knows what resistance you're meant to use.
Pug have a part for doing just that (called a shunt, they used them on the non-airbag models) but when I tried ordering one it's no longer available.
I just took the bulb out.
Posted 21st Jul 2011 at 20:43
stevegti-6
great thanks, so if you rip apart a non airbag model say at the scrap yard, it could be possible to find this shunt part in them?
Posted 21st Jul 2011 at 21:00
Honestly don't know, never even saw one. I think it's in the passenger side dash from a Rallye where there's no passenger airbag.
Posted 21st Jul 2011 at 21:01
stevegti-6
well next time im at a scrap yard i'll have a look, for now I think ill just have the bulb out. Shouldn't be too hard, im sure on here somewhere is a guide
Posted 21st Jul 2011 at 21:19
gti6girl
Last time we purchased a boss it came with this part to plug in. Can't remember which brand tho
Posted 21st Jul 2011 at 21:29
stevegti-6
Well I bought an OMP one and it didn't unfortunately
Posted 21st Jul 2011 at 21:41
jeffers Forum Admin
Mono boss comes with the resistor!!Wink
Team Running Engine again!
Team Negative Camber!
Posted 22nd Jul 2011 at 06:04
stevegti-6
dam it, I wish I knew that before hand, so that must mean I should be able to buy the resistor from somewhere...
Posted 22nd Jul 2011 at 14:42
The resistor is just a standard 2p resistor you could get from Rapid or Maplin, it's just knowing the correct resistance to buy.
Posted 22nd Jul 2011 at 14:50
stevegti-6
yer, surely someone on the forum knows which one. Ill be asking around at pugfest.
Are you going?
Posted 22nd Jul 2011 at 16:39
scottycollard
Hi I ve made a resistor pack for mine as fitting a omp wheel u have to make pack to make 1.6 ohms I had to use about 6 restores for mine just solder them together and have to wires coming off then join them to the multiplug then the light will go out.
Posted 26th Jul 2011 at 21:31
