Author Subject: odd rear brakes???
i've got an odd one. car had its mot and failed on the handbrake. do i done the usaul to sort it out but............the driver side brake locks and the passenger one doesn't. so took the caliper apart and greased lubed etc BUT STILL THE SAME. so i then put a different caliper on............the same. so i took another look and the outer pad doesn't seem to make full contact with the discCrazy Crazy yet everything is flush???? lost on ideas now, and just managed to get the car to past mot. doesnt seem to affect the car while under hard braking but i just want to get it sortedSad
Posted 14th Jul 2011 at 23:47
Sliders siezed up?
Posted 14th Jul 2011 at 23:55
darzmat
nackered cable??
Posted 15th Jul 2011 at 05:00
Even if it is the cable i would think that has nothing to do with the pad not contacting flush Huh? i'll try new cable then.
Posted 15th Jul 2011 at 12:38
The lever arm should pull back so it's slightly more than 90 degrees to the car, if it does that (and then retracts again smoothly) then I very much doubt it's the cable.
If the outside pad isn't making contact it's because the caliper isn't centering properly, and that can only really be the sliders as far as I can think.
Posted 15th Jul 2011 at 13:15
paul_13
We've tried 2 calipers now. Sliders have been free on both. Made sure of this.
My guess is a slightly bent stub axle
205 GTI6- Rebuilt engine, lightened flywheel, lightened pulley, 307 hdi brakes, Koni struts on gravel spec springs, 22mm TB's, 24mm ARB, Roll cage, Citreon ZX rear dampers, SL434's, Xsara box, Quickrack, Pipercross enclosed induction kit. Smile
Private work, not a prob Smile
Posted 15th Jul 2011 at 14:34
