Author Subject: annoying clunk and movement
jimbamboon
i have an irritating clunk / bang from the front passenger wheel whenever i turn right. Everytime i start my journey it clunks on the first right hand turn like something moves then settles mostly when the car is pointing downhill although it also seems to do it when i reverse out of the driveway and drop off the curb, so both times at slow speed. I understand this could be anything, I recently had the wishbones and balljoints and bushes changed because of this but its still there.
I don't know if its related but i tried to rotate the wheels (as they would if they were steering) and there's movement. Should that happen? Rack issue?
clicky code for my benefit
Posted 13th Jul 2011 at 03:48
pugjim
ARB bushes maybe, or if there is play in the wheel then maybe a track rod end.
Posted 14th Jul 2011 at 21:49
jimbamboon
thanks, will look into swapping these is its not too pricey
Posted 14th Jul 2011 at 22:37
paul_13
Have the droplinks been changed? Can't imagine it making that noise but worth checking.
Also do 6's have top mount bearings like a 205?
My mate had a dturbo and the top mount was f*cked making loads of noise.
It's hard to tell what/where the noise is without hearing it yourself
Edit: Just had a look at the FAQ and they do have the same style bearings by the looks of things, could be the bearings dead/dying
205 GTI6- Rebuilt engine, lightened flywheel, lightened pulley, 307 hdi brakes, Koni struts on gravel spec springs, 22mm TB's, 24mm ARB, Roll cage, Citreon ZX rear dampers, SL434's, Xsara box, Quickrack, Pipercross enclosed induction kit. Smile
Private work, not a prob Smile
Posted 15th Jul 2011 at 02:10
jimbamboon
whats the easiest way to diagnose or is it a case of replacing everything to cover all possibilities?
Posted 15th Jul 2011 at 13:24
paul_13
Replace them mate, will lighten your steering up a bit.
2 new bearings off ebay, got a set myself and they're good quality. 10er each.
Posted 15th Jul 2011 at 14:40
Change it all lol thats what i did!
Posted 15th Jul 2011 at 14:41
donny
My golf did this, turned out to be a broken spring....
It was more of a twang than a bang mind.... but made the sound every so often turning one direction.
Donny,
Posted 16th Jul 2011 at 00:12
jimbamboon
This is a definite between bang and clunk, will sort it when I've got the time and energy, doesn't seem to be affecting handling massively at the moment
Posted 16th Jul 2011 at 00:37
beez_neez_gt
Have you jacked up the 6, then got someone to move/wiggle the wheel to see if there is play in the ball-joint ?
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 8th Sep 2011 at 13:20
