Author Subject: purchased 17" but..
marcello
hi there
well i bought these roh stradas although iv been reading the forum and it seems to me im going to come across a few problems, im scared they wont fit straight on
here are my wheel specifications
205/40/17 - 86W
17x7J
any advice would be much appreciated
thanks heeps
Posted 12th Jul 2011 at 19:19
birk
205s will fit on a 7" wide wheel no problems.
Its the pcd and offset of the wheel that is the issue
You need 4x108 with an offset of 15mm or there abouts.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 12th Jul 2011 at 19:23
ryans6
I put 17's on mine, the car handled like poo! I went standard straight away, they look good but your car will feel shit.
BLACK 6
Posted 12th Jul 2011 at 21:16
marcello
yeah they are 4x108 , im a real big newbie when it comes to this ,, but how do i know if they have a 15mm offset?
thanks
Posted 13th Jul 2011 at 06:29
marcello
anyone? Smile
Posted 14th Jul 2011 at 04:25
simonjames
Stamping on the rear will read ET?? that figure is the offset you need 15-18 if the number is higher minus 15 and thats what thickness spacer you'd need
I.E if the wheel reads ET35 - 15 = 20 a spacer 20mm thick is needed
MY EBAY ITEMS
07943066306
Posted 14th Jul 2011 at 04:38
marcello
thanks i appreciate your reply, i went and had a look on the rear but i couldn't find anything stamped with an ET Sad
these are all the stamps on the wheel, also these wheels just came of a ford focus
Posted 14th Jul 2011 at 05:05
ravemercer
will the guy you brought them from know what the et of the wheels are.
Posted 14th Jul 2011 at 18:06
Anything around the front bolt area? Generally Ford wheels need spacers - there will be the spacer size info on here somewhere and get hubcentric ones.
Posted 14th Jul 2011 at 18:26
simonjames
I'd say they were ET29
try them on the car to see
spacer 14-11mm thick is needed
MY EBAY ITEMS
07943066306
Posted 14th Jul 2011 at 18:40
marcello
i couldn't get on to the guy that sold them to me ,,
so just to confirm i should be going to get some
14mm hub centric wheel spacers?
thanks alot for everyones help!
Posted 16th Jul 2011 at 06:59
marcello
i have more information
These wheels came of a ford fiesta 06/07 model
New Fiesta
Year 02>
PCD - 4x108
Offset - 38 to 42
Bore - 63.4
Does this require just spacers, or do i need to change the bore aswell?
Posted 9th Aug 2011 at 09:26
gti6girl
20mm spacers and that's it
Posted 9th Aug 2011 at 13:18
marcello
thankyou!! Smile
Posted 12th Aug 2011 at 15:48
marcello
hi
i bought these 17" rims for my car... there 205/40/17
they came off a ford fiestia so somebody told me to purchase 20mm hubcentric wheel spacers.
so thats what i did
now im having problems
there not moving and theres alot! of friction
Youtube Video of whats happening
http://youtu.be/As070ckdYl8
what should i do now Sad
Posted 15th Nov 2011 at 07:38
cwspellowe
If they were ET38-42 and 7J wide you'd need 25mm spacers.
The spacers you have might have been ok had the wheels been less than 7J wide but as it stands you need an extra 5mm it seems.
Bye bye Sundance Kid Sad
Posted 15th Nov 2011 at 13:20
arigti6
Is there much clearance on the outer arch? If so you it may just be a case of a slightly bigger spacer (23-25mm) If the wheel has a few milimetres of clearance on the outer arch, which being 7J I imagine it should have. Dunno Unfortunately without knowing the correct wheel dimensions it is just trial and error Crazy
Personally I would not buy wheels that are not specific fit for that car/model, certainly not for a completely different make of car, like in your case as it is just aggro Doh Good luck with it though Thumbs up
I Live for the 306 Ninja
TEAM CHERRY PINK RALLYE
2008 BMW ///M 320d
Posted 15th Nov 2011 at 13:29
mik
Spacers are not ideal either - more to go wrong (e.g. longer bolts under more strain, or not enough thread bite using standard bolts) and can have unintended consequences. Best to use wheels that fit it properly. Safer too.
Cherry Rallye SOLD
Posted 15th Nov 2011 at 14:01
Just sell those f*cking awful wheels,Job done Thumbs up
Posted 15th Nov 2011 at 19:28
