Author Subject: is the 1.4 rad smaller then the gti6/d-turbo?
jonnywilcock
hi there
if so how much by? does anyone have a picture?
cheers.
Posted 4th Jul 2011 at 03:11
Prob
Not sure it will have the same inlet/outlets ?
Why ????
Posted 4th Jul 2011 at 03:16
The non-aircon early ph1 version is, it's about 6 inches narrower, and the core is only 15mm thick
Posted 4th Jul 2011 at 03:22
ive been wondering this question, mainly wether you can get a rad that fits without the reservoir part on the left been as big as it is.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 5th Jul 2011 at 01:50
jimmyhackers
i own a phase one 1.4 and a gti6 Smile how lucky for you Razz
yes its a smaller rad with a single fan, expansion tank part is same size and with some jiggery bodgery it would fit hose/mounting wise.
not sure about swapping fans and why youd want a smaller radiator?
Posted 5th Jul 2011 at 01:54
jonnywilcock
run boost pipes down the side, thanks. Smile
Posted 5th Jul 2011 at 17:09
^^Well, I switched to a bigger radiator as the 1.4 one struggled to keep even my engine cool on summer trackdays...so it might not be as good an idea as you think!
Posted 5th Jul 2011 at 17:12
jonnywilcock
someone i know on club-306 is running the 1.4 rad but im not sure if hes ever ran it over summer!
im going to run the 1.4 anyway and if it becomes too much for it over summer il change back to the d-turbo rad or something.
what rad are you using phil? any pictures of where you ran your boost pipes?
thanks. Wink
Posted 6th Jul 2011 at 03:45
My boost pipes are rather easy to run...Wink
I'm on the Ph2 1.4 air-con version, which is the same thickness but wider.
Posted 6th Jul 2011 at 04:36
ive been thinking about this and the solution ive come up with wont be cheap, basically you want to fit 2.5 inch boost pipes but it doesnt fit, just.
so buy an alloy rad, like nissens, take to a alloy rad and tank engineers get them to take off the black plastic reservoir and fit/weld a new one on thats an inch or so shorter.
Posted 7th Jul 2011 at 04:36
jimmyhackers
am i missing somthing? ive already been lectured on here about the vitalness of the cooling system Razz
possible overheating for a fart in a tornadoes worth of performance?
im probly being a noob here but the only benefit i can see from a smaller rad is weight reduction and maybe space saving.
if this has already been discussed anychance of a link to the thread?
Posted 8th Jul 2011 at 07:08
He doesn't want a smaller rad he just needs the expansion tank to be an inch shorter to fit a pipe through.
Posted 8th Jul 2011 at 16:01
jimmyhackers
pipe? how old fashioned
use bluetooth man
Posted 9th Jul 2011 at 01:24
Posted 9th Jul 2011 at 01:30
jimmyhackers
theyve invented blutooth air, water, oil etc now Razz
Posted 9th Jul 2011 at 04:43
Pity they haven't invented bluetooth brains eh?
You could have got a time share on one Razz
Posted 9th Jul 2011 at 04:47
jonnywilcock
now now Big grin
Posted 9th Jul 2011 at 16:04
Ok i get it, so theres no need for boost pipes as you can just Bluetooth the charge air from the charger to the intercooler, cool the air them bluetooth it again to the inlet manifold?
Why bother with a car then why not just Bluetooth ourselves to where we need to go?
Posted 9th Jul 2011 at 17:20
jonnywilcock
the future right there LOL
Posted 11th Jul 2011 at 19:52
