Author Subject: pattern cat lamba plug further away
jimmyboycheck
Got a pattern cat went to fit and straight away i saw the issue of the springs having no pressure as the nut could go no further so could use diffrent bolts etc.
But the lamba sensor wont reach to the place where it needs to go Huh?
Silver 6
Posted 2nd Jul 2011 at 04:07
jimmyboycheck
anyone with any advice
Silver 6
Posted 2nd Jul 2011 at 15:38
Rich E Forum Admin
Suggests it's not the correct part?
If you unclip the lambda sensor plug from the body then you should be able to get a little bit more slack on the cable.
Failing that you have two options; Extend the sensor wiring or take the cat back.
Posted 2nd Jul 2011 at 16:46
jimmyboycheck
thanks for the reply rich.
after closer inspection cat not the right part.
Euro parts are fail all the time not going to use them for exhausts ever again!!!
Silver 6
Posted 3rd Jul 2011 at 02:34
