Author Subject: Engine wiring loom plugs
I have a broken engine wiring loom plug. It has snapped where the wire goes into the connector.
Are they available to buy from Peugeot? Or is it a scrapyard cut of and solder job?
  • Posted 27th Jun 2011 at 03:28
    ablister
    if its the big multi plug connector that joins main loom at OS chassis rail then you can buy them from peugeot but they are really expensive (possibly £70+). It's basically the same connector that is used on the door wiring loom repairs but a straight connector instead of the 90 degree one
    306 rallye, Richard Longman engine
    rc10gt
    Posted 29th Jun 2011 at 00:29
    It's just a connector for what I believe is for oil level/temp or whatever it is.
    It's attached to the sump IIRC and light blue.
    I have got a couple of light blue plugs from a Saxo which have the same purple centre inside, so will hope one of them fits the same way.
  • Posted 29th Jun 2011 at 04:04
    ablister
    yeah, those connectors are found on alot of different peugeots. Best to go to scrappy and cut a similar one off.
    rc10gt
    Posted 30th Jun 2011 at 00:14
    pugjim
    Im sure somewhere on the megasquirt sites you can get them new with the crimp on pins. I got some when i built a loom for a dta.
    Posted 30th Jun 2011 at 03:01
    ravemercer
    asked peugeot about a plug for a icv was told no they just sell certain bits of the loom tho
    Posted 1st Jul 2011 at 18:04
