Author Subject: Cat fitting kit
cwspellowe
Anyone know why I seem to have two different length bolts holding my cat on? Was a genuine cat fitting kit from Peugeot, never thought anything of it when I first fitted the decat but having come to fit the cat it doesn't sit up tight, one of the nuts has reached the end of the thread, the bolt's about 10mm too long Dunno
Bye bye Sundance Kid Sad
Posted 25th Jun 2011 at 05:31
smegal
The genuine kits come with a few different bolts. I guess different combinations of manifold and cat had thicker and thinner flanges.
Ex SC-6
Now in a Megane R26
Posted 25th Jun 2011 at 18:28
Rich E Forum Admin
It's used on several different models so there's three different pairs of bolts in the kit.
The middle of the three lengths is the correct one for the 306.
cwspellowe
crap, looks like i need a new kit then. Could swear i used the right ones..
Posted 26th Jun 2011 at 03:04
footah212
I bought a kit from ECP which had the proper bolts but need about 2 washers each side to make them fit. As you know its a well fiddly job and trying to get the washers on without it out all the bits falling off and hitting me in the eye proved to be difficult.
I ended up using a normal bolt which had a tread all the way to the head. It worked perfectly, just need to be careful you don't overtighten. There should still be some space for the springs to flex.
Don't think different bolt lengths will matter so long as there is some movement in the spring.
Hope this helps
Phase 2 Blaze GTi6
PS3 - Black Ops 2
Posted 28th Jun 2011 at 03:16
