Author Subject: Standard cat to sleeve fit magnex
eddiebeano
Hi, just got hold of a magnex today with a sleeve fit-to-cat centre section. Assuming the cat is standard which uses a normal peugeot type clamp, how would i go about joining them? Would i have to cut the fitting off a standard centre section and weld it to the magnex centre section or is there a fitting i can buy to convert it to a clamp fitting?
team: Stealth Ninja
Posted 24th Jun 2011 at 03:32
remove centre section, slide magnex over cat pipe, fit clamp.
job done Smile
Posted 24th Jun 2011 at 03:42
eddiebeano
ok cheers!
team: Stealth Ninja
Posted 24th Jun 2011 at 03:51
cwspellowe
Wait a minute.. does that mean the decat that was fitted to the Magnex will fit a standard centre section?
EDIT no it wouldn't actually, there'd be no way of clamping it as the decat has no olive, just a sleeve
Bye bye Sundance Kid Sad
Posted 24th Jun 2011 at 03:59
eddiebeano
assuming it is the same bore (2.5) as you thought, it should fit inside, but the standard centre section is flared..
If sleeve fitting on the straight through centre section is a standard magnex, it should fit over the sleeve on the standard cat right?
team: Stealth Ninja
Posted 24th Jun 2011 at 04:02
cwspellowe
Should do Thumbs up
The mid section is still the original magnex pipework but with the silencer cut out and replaced with pipe so magnex fittings Thumbs up
See if i've knocked £20 off and it still fits i'll cry
Posted 24th Jun 2011 at 04:05
eddiebeano
It was mighty good of you though Thumbs up
team: Stealth Ninja
Posted 24th Jun 2011 at 04:15
lotek
the cat has a flared bit (foreskin) and a potruding bit (bellend)
the magnex sleeve (vagina) slides over the bellend and butts up against the foreskin Smile
Posted 24th Jun 2011 at 13:58
Laugh my ass off
Posted 24th Jun 2011 at 15:37
eddiebeano
Haha, what do you reckon this setup would sound like? Cat to straight through magnex?
team: Stealth Ninja
Posted 25th Jun 2011 at 03:16
shadows entity
Boomy
Posted 25th Jun 2011 at 03:19
eddiebeano
Have you got this setup?
team: Stealth Ninja
Posted 25th Jun 2011 at 03:26
