Author Subject: clutch arm removal...
Removing gearbox today, all loosened off lovely and tried to pull off and remembered clutch arm. I punched the clip the end where the spring is... opps and then realised it needs to be pulled out, not knocked through.
My issue is I have no end to grip to pull, and i cant force it back from behind as theres no room.
What are my options?
My citroen mechanic said get a bar in the box and rip it off, but im not liking that idea!
  • Posted 22nd Jun 2011 at 01:28
    tvrfan007
    Lever it from behind with a driver, you should be able to swing the arm far enough to get something.
    Or
    Bend the arm upwards and straighten it afterwards once it's off - bend it far enough and the arm will rotate further and disengage from the clutch.
    Or
    Cut the arm off and get a new one afterwards.
    I'm Si btw Tee hee
    Night Blue VW Golf GTD
    Posted 22nd Jun 2011 at 01:32
    razkin
    You can drill it out, the metal of the pin is not really hard.
    Citroen ZX 16V
    Citroen ZX TCT
    Posted 22nd Jun 2011 at 01:54
    Are the pins available from Pug?
    Might aswell drill the fecker out
  • Posted 22nd Jun 2011 at 02:02
    tvrfan007
    Pins are available from Peugeot but order in only. Inexpensive.
    I'm Si btw Tee hee
    Posted 22nd Jun 2011 at 02:10
    WD40 + mole grips after knocking it through from the back.
    Posted 22nd Jun 2011 at 02:11
    Ive wound some spring compressors around the arm and the cable plate, but cant for the lofe of me beat or force the pin back through.
    All this hassle when the FAQ explained all. Sigh.
    Will call it a day and look at it again tomorrow.
  • Posted 22nd Jun 2011 at 02:28
    ravemercer
    Try an allen key to push it through a bit the grips could drill a pilot into it and screw a small screw in then pull from there if
    Pin part no 2172 09 £3.02inc
    arm pin and fork only as a kit part no 211527 £63.76
    was on service box looking at £150 driveshafts Sad
    Posted 22nd Jun 2011 at 02:38
    Didnt think of the small screw idea!
    Thanks for the part numbers.
    I have plenty of driveshafts here if you need one.
  • Posted 22nd Jun 2011 at 04:02
    ravemercer
    is the box off the engine might strugle to get a drill in the bay decent length of screw thread thread in there could work good luck Smile
    might have to take you up on a pair of shafts i'll let ya know
    Posted 22nd Jun 2011 at 13:47
