displaying posts 1 to 25 of 48
Author Subject: Feel like crying lol
l8un08
Just had my car back off a mate he did the headgasket! I drove it for about a day and now the car has overheated and spat out the water again! Have the gasket gone again? Or has something caused the engine to overheat which is why the gasket went the first time! I.e radiator or waterpump or something? So annoyed! The head was crack tested and skimmed so the job was done properly! Bit worried about driving it at the moment as I don't wanna do any damage so the 'mate' is coming to pick her up asap!
bloooobirds
Posted 12th Jun 2011 at 14:10
l8un08
Still crying lol
bloooobirds
Posted 12th Jun 2011 at 15:00
davedgti6
Could just be an airlock
Posted 12th Jun 2011 at 15:16
its probably airlocked, did he bleed the coolant system properly and use the pop bottle method to raise the height of the fill up point higher than the matrix?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
there is a guide/threrad on here showing exactly how to bleed the coolant system and it works perfect
Posted 12th Jun 2011 at 15:17
l8un08
Thanks for the reply guys! Um the car drove fine for about a day or 2 though! Would this rule the airlock out?
bloooobirds
Posted 12th Jun 2011 at 15:23
Did you replace the thermostat ? Where did it spit the water out from ?
Are the fans working when its hot ?
Bit more info required please me old bread bin ????
Posted 12th Jun 2011 at 15:31
l8un08
Hey, yes thermostat was replaced! The water is coming from
The overflow pipe! Usually when Iv turned the engine off! The fans do work but I'm not sure if there doing the job it's meant to! I'm not mechanically minded as a friend did the job! Yesterday he told me to take the valve off rad and fill to brim of water then when water comes out lock it back on! Does that mean it's been bled or no? Thanks
bloooobirds
Posted 12th Jun 2011 at 15:36
no, you have to do the pop bottle method
Posted 12th Jun 2011 at 15:42
l8un08
Ok guys! What would have caused my head gasket to have blew in the first place?? Which bleeding points need to be opened as I have problems finding them! It's an odd ball engine apparently, it's a 1.8 auto but the only gasket that would fit was a 2.0l 8 valve! I'm so shit with cars guys so sorry in advance
bloooobirds
Posted 12th Jun 2011 at 16:10
errr, that doesn't make sense, the 2.0 is 86mm bore, the 1.8 83mm...
so the fire rings will not be sat on the top of the liners properly...
Posted 12th Jun 2011 at 16:33
l8un08
I'm not sure mate but all I know is that both the 1.8 gaskets that peugeout supplied wouldn't fit! The engine is an odd ball with no engine number either, maybe imported or something?
bloooobirds
Posted 12th Jun 2011 at 16:37
l8un08
So do we think the gaskets wrong guys? By the way the guy who did my car has had a garage for 12 years so surely he wouldn't make that mistake? Or would he lol
bloooobirds
Posted 12th Jun 2011 at 17:20
davedgti6
I don't understand why you had trouble getting the right gasket from Peugeot, you just go into Peugeot, give in your registration number and they "should" hand over the correct gasket, as a back-up I would have taken the old gasket with me to compare, if you have used the wrong gasket, as said the fire rings might not seal correctly or a vital hole might be missing and a water or oil supply blocked,
unless the engine has been changed to one out of a Cinquecento or summit (common mod I here) Whistle
Posted 12th Jun 2011 at 18:04
l8un08
Haha! I didn't go to peugeout directly! Went to welsh auto parts they supplied me with 2 gaskets for a 1.8! neither fitted so we took the old gasket and they matched it up with a gasket, I'm pretty sure from a 2litre pug
bloooobirds
Posted 12th Jun 2011 at 18:12
davedgti6
Has the car had an engine swap or bottom end change then to a 2 litre model?, If you could post up a pic on here of the old gasket and measure the bore size of the piston aperture then there will be some perv off here that will be able to tell you what engine the gasket is off,
Also was the new gasket a MLS one (Multi layered steel) as Peugeot supply or a fibre one?
Posted 12th Jun 2011 at 18:27
davedgti6
Did the new gasket look similar to this?
Posted 12th Jun 2011 at 18:37
l8un08
I didn't pick up or fit the new gasket! Although the old one looks like that just a bit flimsier and brown! I have the old gasket in my boot so il try get a pic up asap! Also I don't think the engine has had anything done and it was in the family since brand new
bloooobirds
Posted 12th Jun 2011 at 18:38
l8un08
The old gasket was just one layer so definitely not like that one
bloooobirds
Posted 12th Jun 2011 at 18:40
afaik the alloy blocks used the composite gasket not the MLS.
Posted 12th Jun 2011 at 18:42
davedgti6
Sounds like it could be the wrong gasket fitted then Sad , or if this engine has wet cylinder liners fitted was the cylinder liner protrusion checked? , if not and the protrusion was not correct (too low) then no gasket will seal correctly,
Posted 12th Jun 2011 at 18:45
davedgti6
Ahh so it does have liners then,
Edit ;- is this the case for all the alloy blocks?, as pug supplied a mls one for my 106 1.4D when I did that headgasket
Posted 12th Jun 2011 at 18:49
l8un08
I no the car does have wet liners as he mentioned it before hand! If it means the liners were too low then where do I go from here? Is the head f*cked again? Do I need to do everything again? New head gasket skimmed etc?
bloooobirds
Posted 12th Jun 2011 at 18:47
davedgti6
When I had one done the liners had somehow gone lower into the block, I took it to an engine builder who decked the block (reduced its height) and then matched up the liners to the correct protrusion specs with new O rings,
Yours sounds like it could be wrong gasket
Posted 12th Jun 2011 at 18:54
l8un08
Hmm I'm not sure il upload a picture now! Surely a guy with 12 years experience couldn't put the wrong gasket on??
bloooobirds
Posted 12th Jun 2011 at 18:57
