Author Subject: Rounded ARB End Caps
ic0n
Hi,
Stupidly bought a M12 bolt without double checking if it was 1.5mm thread...
EDIT
I've rounded the ARB end cap holes, I was using the method where you put a bolt into the ARB end cap to push it out.
Posted 3rd Jun 2011 at 16:28
I think a picture of the area might help as your description sucks.
Posted 3rd Jun 2011 at 16:27
ic0n
edited...
Posted 3rd Jun 2011 at 16:29
So what's the question?
Posted 3rd Jun 2011 at 16:30
Do you mean you have stripped the threads in the ends of rhe ARB?
ic0n
Yea the ARB end plate threads
Just wondering how to get the caps off now?
Posted 3rd Jun 2011 at 16:33
Might be able to get a crowbar under the plate to remove one end, you can then slide the ARB out from the other end.
Posted 3rd Jun 2011 at 16:35
Tyre levers or a puller is the only way now, unless you can do a helicoil thread repair in-situ.
chris with a pug
you could also remove that bolt and get a drift in the hole and beat the arm out the other side
Posted 3rd Jun 2011 at 18:48
You will want to put a bolt in the thread in the arb though or else you will damage the threaded hole witht he drift. (Typical answer from Chris though, his first resort is always a big hammer) Wink LOL
Personally I'd weld a stud to the plate and just use a slide hammer to pull the bugger off, but thats me.
Posted 3rd Jun 2011 at 18:52
chris with a pug
not everyone has access to slide hammers and welders Razz
Posted 3rd Jun 2011 at 20:03
Smug BFH technology it is then Wink
(BFH = Big f*cking Hammer)
Posted 3rd Jun 2011 at 20:07
You don't need both.
If you buy a welder, you can make a slide hammer Razz
cooper666
cant you drill it out and tap it to a m14
clio r27
ps3 id:cooperkloe
Posted 3rd Jun 2011 at 21:38
