Author Subject: Stuttorama!! Name the problem!
rallyestyle
Well try to name it anyway....
Start car up, idles fine for around 1min, then stutters on idle as seen in this vid:
Take it for a drive and stutter persists through the rev range.
Have changed the stepper, no difference.
Have unplugged the lamda and left it to idle, same issue.
Whats next would we say, Map sensor?
Have checked and cleaned all the other sensors and they seem fine Dunno
Cheers all Thumbs up
Pint to the man that gets it right Cheers
Just Drive It
Posted 1st Jun 2011 at 03:16
bukosgti6
map.
Posted 1st Jun 2011 at 04:46
ryangti6
Going on it getting worse as it starts to warm I'd point to the green cts.
Have you taken the plugs out to see what they look like?
Ryan
Posted 1st Jun 2011 at 19:05
I think its f*cked and i'll give you £250 for it. And a bag of crisps which i've just eaten.
CTS could be a winner, i'd compression test it too just to be sure.
Posted 1st Jun 2011 at 19:17
lotek
blow down the exhaust pipe Yes LOL
Posted 1st Jun 2011 at 19:18
smegal
Are you ever up north, Tom? I'll plug it in if you like and we can work out what it is.
When my CAY blocked it had diff symptoms so I would rule that out.
Ex SC-6
Now in a Megane R26
Posted 1st Jun 2011 at 20:12
rallyestyle
Sadly not mate, its off the road at the moment back at my parents Yes
Aware i might be asking a stupid question but whats CAY?
Just Drive It
Posted 1st Jun 2011 at 21:17
lotek
he meant cat Yes
Posted 1st Jun 2011 at 22:56
smegal
lotek wrote:
he meant cat Yes
Cheers LOL. I can be a dumbass at times.
Ex SC-6
Now in a Megane R26
Posted 2nd Jun 2011 at 00:58
Just so as you know, Tom and I reached an agreement earlier today and this is now set to replace the Volvo.
Cheers matey! Thumbs up
Posted 2nd Jun 2011 at 01:55
First thing I'd do is fix the tapping.....
Posted 2nd Jun 2011 at 02:07
cwspellowe
+1 for CTS. I bought one from Pug the other day, was only £20 or so. Worth doing just to at east rule it out Thumbs up
Bye bye Sundance Kid Sad
Posted 2nd Jun 2011 at 02:27
That'll be Ash on the front window LOL
Posted 2nd Jun 2011 at 06:43
rich_w
Through what rev range does it stutter?
Does it do it throughout the whole rev range, or just at the low end?
Contact Details:
07732 822546
Posted 3rd Jun 2011 at 18:32
rallyestyle
It does it while it idles and then it does it through the rev range from what i can remember, i havent had it anywhere near the redline for a while No
Just Drive It
Posted 3rd Jun 2011 at 18:36
Cylinder 2 is f*cked IMO Thumbs up
Posted 3rd Jun 2011 at 20:09
SteviePut
Coil pack?? Try un-plugging one in turn until the the right one is found. At the very least it'll tell yoo which cylinder is the problemSmile
Posted 4th Jun 2011 at 01:06
rallyestyle
Think its getting down to that, just changed the green CTS sensor and no change Doh
Noticed when i took it for a spin that the water temp is not showing Hmm
Just Drive It
Posted 5th Jun 2011 at 21:36
smegal
Go over all the extended wires and see if manipulating them stops it stuttering.
A soldered joint could have come loose, so a sensor is reading odd. I'd get it to someone who has diag equipment, sensor roulette is expensive, diag will also tell you if you have any wiring issues. It told me that my TPS wires were shorting out.
Ex SC-6
Now in a Megane R26
Posted 5th Jun 2011 at 21:56
rallyestyle
Ok thanks mate Smile
Are there people that will have diag equipment and come out to take a look do you know?
Just Drive It
Posted 6th Jun 2011 at 14:41
bukosgti6
Did you sort this tom.
Posted 17th Jun 2011 at 01:42
rallyestyle
Not yet mate. As the car is at my parents i dont get to spend time on it too often Doh
I need to cook up some new options, im thinking of taking a punt on the MAP sensor if i cant get a diagnostics guy to come and have a look at it Yes
Just Drive It
Posted 17th Jun 2011 at 16:11
bukosgti6
My map was shagged. Unplug it and go for a drive it wont tick over as it should but at lest you will no if it is the map fingers crossed 4 ya
Posted 17th Jun 2011 at 18:25
405gti6
I had bad stutter on my 405 when the inlet manifold gasket was shot. Was drawing in unaccounted for air obviously.
XU10J4RS powered 405 Big grin.
Posted 21st Jun 2011 at 03:08
