Author Subject: Rallye doesn't handle well
techdw
I have done some searchs, but When I drive the Rallye and Pick up speed the car feels so unstable it feels like im going to crash into something, i dont like the steering response and want to sort it asap!
Now what can I upgrade and what parts should I just replace with Std items or after market parts? for example, Bushs, ARB, Susp Arms, rear beam mounts and so on
The car currently has KW Coilovers at the front and set Stiff - Max
Rear has been lowered and can Koni Ajustable Shocks its set on Medium id says but can see wr to ajust it
Posted 29th May 2011 at 07:06
lotek
turn front dampers to soft and harden in small amounts over time,
change wishbone bushes and get tracking done.
will transform it
look at hybrid ARB and solid beam mounts also
Posted 29th May 2011 at 07:50
KWs - i'd do what Lotek says.
Beam ok?
Beam mounts ok?
Whats wrong with the steering?
Posted 29th May 2011 at 14:01
techdw
Cheers Guys. Adam, the Steering doesn't feel responsive, and when Im driving at speed and go move the wheel left and right very slightly it feels like it turns a second later then when I have turned the wheel if you see what I mean.
Hybrid ARB and solid Beam mounts, wrs the best place to source these?
Posted 29th May 2011 at 17:35
lotek
STOP DRIVING THE CAR.
you have an ovalised hub Yes
the hole where the balljoint has ovalised, there is a very high chance of it coming out , if it does you WILL crash and do alot of damage.
Posted 29th May 2011 at 17:49
techdw
Ah great!lol
Can I just change the whole susp Arm to solve this? Im abit of a newbie when it comes to the susp side of these cars.
Posted 29th May 2011 at 18:08
matt evans
Could be a worn or pair of worn track rod ends, that could also introduce a slack feeling in the steering.
But like Lotek says, get it checked quickly as TBH the steering of the 306's cant normally be faulted (except the shit lock lol)
honestly3k wrote:
owain wrote:
Posted 29th May 2011 at 22:56
techdw
I think Ill change the DropLink, TrackRod Ends, and Susp Arms all at the same time, tho it could only be the one thats at fault.
Posted 30th May 2011 at 04:07
midlife
My money is on the beam mounts being fubaredGeek
Cool
Team 330™Cool
Team "no front end or engine"
Posted 30th May 2011 at 04:32
Bit OTT Laugh
Posted 30th May 2011 at 04:47
720puggti
Well you learn something new everyday.
I would definitely check those ball joints, as those symptoms you've described Wayne, do align with what lotek is suggesting.
I'm sure you know what you're doing mate, but you've got my number and you know where I am.
Deepak Gohil
Posted 30th May 2011 at 04:59
techdw
I am going to check tomorrow and may give you a call mate. Really isnt a nice feeling even at 70mph!!
Posted 30th May 2011 at 05:07
720puggti
I imagine it can be unnerving.
But hopefully, whatever it is, you'll nip it in the bud.
Deepak Gohil
Posted 30th May 2011 at 05:17
gman
I'd also check that your subframe is secured properly
1992 Onyx Black 205 GTI-6
2005 Honda S2000 (Sold)
2002 Audi S3 (Sold)
2005 Clio 182 Trophy (sold)
techdw
Had a good look under the car today/ The drop Links when I grab then they have some movment in them as in I can really turn them left and right.
Posted 30th May 2011 at 23:20
lotek
the symptons you have described are 150% gonna be a ovalised hub Yes
question is what one.
you can check yourself when jacked up or take it to MOT centre and use the machine the have that shakes car
Its the Hub itself that will need changing
Posted 30th May 2011 at 23:45
techdw
I just had all the front wheel bearings done at Lynx, will gutted if the hubs need to be replaced.
Posted 31st May 2011 at 00:28
lotek
better to find out sooner rather than later, its usually the drivers side that goes.
and usually the 16mm Bj hole opposed to 18
Posted 31st May 2011 at 00:34
techdw
wrs best to source the new parts Lotek and thanks for all the advice mate
Posted 31st May 2011 at 00:41
could just be knackered BJ's and P-bushes, these feel quite similar to a worn hub.
check the BJ pinch bolts are the correct ones (i.e should have a shank) and are done up to 23 lbft.
Posted 31st May 2011 at 01:16
techdw
Lynx replaced the BJ pinch bolts, im sure they would have used the correct bolts
Posted 31st May 2011 at 01:40
mark.evs
I've cracked a hub across the ball joint doing up a pinch bolt, the car was all over the place, get it jacked up before it comes out and causes loads of damage.
My GTi6 track project
White Rallye project
Posted 31st May 2011 at 14:49
Easy to overtighten the pinch bolt and knacker the hubRoll eyes
As Welshpug says,check the torque on bolt,23 lb ft is hardly anything more than hand tightSmile
Posted 3rd Jun 2011 at 02:57
ronburgandy
Just seen this - I'd say you need to fit some solid rear subframe mounts on the car as the coilovers totally stiffen up what was originally designed to be quite a supple car (solid mounts were next on my list before i sold it).
The standard rubber passive stear mounts are likely to be in alrght condition but the firmness of the rest of the set up will over exagerate them.
I take it your issues with the steering at high speed are the with passive rear steer and the fact that it feels like the back end is wagging around a bit when you correct the steering.
Posted 19th Jul 2011 at 04:29
Did you ever get to the bottom of this?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 18th Sep 2011 at 13:32
