Author Subject: valves replaced and still tapping
deano9621
had 6 bent valves and replaced 8 had the head fitted properly by the same guy that fiited my last 6 head but this time its still bloody tapping,and he thinks it can only be the lifters (tappets) it is a little smokey when you give it a blip on tne throttle....any suggestions as i am loosing faith nowAngry
french forever
T859HFC now goneSad
T534 KVR now new homeSmile
Posted 27th May 2011 at 03:13
jeffers Forum Admin
Damaged valve guide or there's still a bent valve in there.Wink
Team Running Engine again!
Team Negative Camber!
Posted 27th May 2011 at 10:12
As above,guides prob damagedNinja
Should check the guides as a matter of course,mine needed all exhaust valve guides replacing due to age/wearWink
Posted 28th May 2011 at 02:24
Guides deff need changing
Posted 28th May 2011 at 02:38
miles
Almost deffo the head, Everything should of been checked but I know from the Guy I use even heads that have been done are found to have issues, One reason why I would only trust 2 companies in the UK for this job
www.pugracing.com
Posted 28th May 2011 at 04:25
deano9621
cheers for all the help guys,just found out that the bent valves were replaced..but the machine shop did not replace the guides....aarrrrggghhh
french forever
T859HFC now goneSad
Posted 28th May 2011 at 20:47
miles
The guides rarely need replacing, They can be checked thou which is all or should be part of the course
www.pugracing.com
Posted 29th May 2011 at 02:56
deano9621
is there a good mechanic in my area that could do the head on my rallye as i am getting fed up of the answers,saying it wont run on bent valves or its the tappets,as i want to get it sorted once and for all nowSad and cant keep spending moSad ney all the timeAngry just want someone who knows what there doing...cheers
french forever
T859HFC now goneSad
Posted 7th Jun 2011 at 00:27
Car - Mechanical repairs can sort you out with a tap free head or try rich w or I'm still in contact with an ex longmans employee Smile
Posted 7th Jun 2011 at 00:32
deano9621
cheers mate,can i send the head to any of them..or can they collect to repair...cheers
french forever
T859HFC now goneSad
Posted 7th Jun 2011 at 01:52
carl does exchange nontapping heads i believe
Posted 7th Jun 2011 at 02:13
deano9621
cheers rikky mate,sent pm just waiting for reply...cheers deanoWink
french forever
T859HFC now goneSad
Posted 7th Jun 2011 at 02:22
