Can anyone remember what it was?
Ex SC-6Now in a Megane R26
| Author | Subject: Brake squeal solved[ish] |
smegal
A few years ago someone posted up a link to some stuff that you put on the friction part of your pads to stop squeal.Can anyone remember what it was? ________________________________________ Ex SC-6Now in a Megane R26 |
lotek
Seasoned Pro Location: Berkshire Registered: 04 Dec 2007 Posts: 6,107 Status: Offline |
yeh copper grease... ![]() look on camskil or ebay and its mintex squeel stop or somethin like that. |
smegal
Anyone remember what this was?________________________________________ Ex SC-6Now in a Megane R26 |
YOU MAY NOW FELLATE ME.Took forever to find the thread but it started to p*ss me off, and I couldn't stop looking. This is the product, and this is the thread. Damn, that was not fun. ________________________________________ Membership expiring soon, get in contact on our new little forum project. |
smegal
I now owe you fellatio. I could NOT find that f*cking thread.________________________________________ Ex SC-6Now in a Megane R26 |
cwspellowe
Seasoned Pro Location: Calderbank Registered: 19 Jul 2009 Posts: 6,496 Status: Offline |
Does anyone know if that stuff works? The blurb says it targets air pockets in the friction material,I thought the squeal was resonance from the disc?________________________________________ Bye bye Sundance Kid |
Pads are always slightly porous, even after pyrolysis, I'd guess it just sets up as a resin in the pores and makes the pad structure slightly stiffer with more internal damping. Absorbs a little of the resonance but more importantly problem shifts the frequency it occurs at. ________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
iplay
Seasoned Pro Location: Number Wang Registered: 18 May 2006 Posts: 3,272 Status: Offline |
to reduce/eliminate squeal bevel the front and rear edges of the brake pads without touching the inner or outer edges. Add some copper slip behind the pads. Clean up the face plate with a little copper slip around the hub to seat the disc.Could a slightly worn wheel bearing make brakes? squeal? |
iplay wrote: to reduce/eliminate squeal bevel the front and rear edges of the brake pads without touching the inner or outer edges. Add some copper slip behind the pads. Clean up the face plate with a little copper slip around the hub to seat the disc. Tried that all on my Brembos, didn't make a blind bit of difference. ________________________________________ Membership expiring soon, get in contact on our new little forum project. |
smegal
When I am not getting bent over by my exams I'll try and source some of this.I have temporarily quietened my brakes using: This These I also removed the rust and ground the lip off the discs and filed a tiny chamfer on the leading and trailing edges of the pads. Let's see how long they stay quiet for. ________________________________________ Ex SC-6Now in a Megane R26 |
smegal
If anyone else wants any there are group discounts here________________________________________ Ex SC-6Now in a Megane R26 |
24seven
Seasoned Pro Location: Derby Registered: 05 Oct 2005 Posts: 6,221 Status: Offline |
I had chronic brake squeal on the 206 GTi 180 brakes a I fitted to my 306 XS for a bit, and we've had the same trouble on the uni Formula Renault we're running. Both times it was a manufacturing defect in the pad where they contact the sliders. On the Renault there's a U pin that goes through the calliper and holds the pads in place. There were burrs in the edges of the holes this pin goes through. On the 306 the shoulders of the pads where they slide were burred as well. It's always worth taking your time and making an effort to clear any dirt/debris/rust away from the sliders, make sure they're as smooth and flat as possible then put a thin smear of copper grease on them only where the pads are actually in contact with them (otherwise they collect dirt and dust and the grease just makes things worse) before the pads go in. ________________________________________ Ph1 306 GTi 6 | RX8 231 S1 | YBR 125 Cafe Racer | MT-03 660 |
