displaying posts 1 to 25 of 31
Author Subject: Brown Liquid
notoriouslor
Just stopped to put some petrol in the car had been driving about an hour when a light brown liquid started flowing from the front drivers side of the car. Sorry for my ignorance but does anyone know what this is?
Posted 19th May 2011 at 23:40
fozzy_255
Radiators leaking mayb, check the levels
Posted 19th May 2011 at 23:44
justinaccurate
Check your pants? Any unusual smells? Wink
Posted 19th May 2011 at 23:49
notoriouslor
I'm looking after the boy while my better half is at the shop's otherwise I'd go out and check but it looks like it had stopped when I got it back to the house, it was probably about a 500ml bottle worth maybe a little more, I thought coolant was red? This stuff was a very light brown colour
Posted 19th May 2011 at 23:50
notoriouslor
Na I had my son in the car so wasn't driving fast enough to be crapping myself, lol
Posted 19th May 2011 at 23:52
notoriouslor
Anybody any ideas?
Posted 20th May 2011 at 02:15
gilesy
How about your son?
LOL
Posted 20th May 2011 at 02:19
gilesy
What is your fluid level like in the rad now?
Posted 20th May 2011 at 02:20
mik
Sounds old and in need of replacement whatever it is. Old rusty coolant sounds likely. Did you do the fingertip dip and sniff (!) test? Is it water or oil-based?
As above check all fluid levels.
Cherry Rallye SOLD
Posted 20th May 2011 at 02:28
notoriouslor
Just had a chance to look at it just now but it is getting dark out but it looks like it was the coolant that has emptied, any usual suspects for this? Any well known reasons? Big job's to put right? Sorry about all the questions guys but I'm very new to this car, and it already doesn't look like the love affair is going to last Sad
Posted 20th May 2011 at 02:40
fozzy_255
Bottom radiator pipe or radiator leaking is my guess
Posted 20th May 2011 at 02:53
gilesy
Have a proper look in the daylight, top the water up at the very least. If a hose has gone then it will leak out either there and then or immediately upon moving.
You may need to bleed your system too if it has emptied out
Posted 20th May 2011 at 02:57
notoriouslor
How easy is it to bleed the system?
Posted 20th May 2011 at 03:04
fozzy_255
Pretty simple to bleed. Have a search on the forum, if no luck get a haynes manual, you will be sure to use it again
Posted 20th May 2011 at 03:08
notoriouslor
Cool, thanks for the help guys, I'll hopefully get a decent look at it tomorrow when I get back form work, I'll try and pick up a haynes from Halfrauds as well
Posted 20th May 2011 at 03:16
mik
If it is coolant, it will be old hoses or radiator simply needing replacement - they don't last for ever.
Not a big job at all - well within the ability of a moderately knowledgeable enthusiast.
Old cars need stuff doing on them as parts wear out. It is as simple as that. Cars cost money - what you save on what depreciation would cost on a new car you make up for to some extent on an old car in increased maintenance. The key to old car ownership is checking service history to make sure you are not paying for former owners' penny-pinching!
Cherry Rallye SOLD
Posted 20th May 2011 at 03:20
notoriouslor
Lesson learned, hopefully not as big a job as I first thought anyway
Posted 20th May 2011 at 03:49
jeffers Forum Admin
Rad cap failing?? .... I had this last year worth a shot! Wink
Team Running Engine again!
Team Negative Camber!
Posted 20th May 2011 at 05:51
Right then:
1. Rad cap seal failing
2. Airlock in the system due to leak - gets hot and forces coolant out the drain pipe. Heater matrix may have gone too.
3. Head gasket failure
4. Heat exchanger failure
5. Does it have any antifreeze in it? Sounds like it possibly didn't.
I'd put my money on numbers 5 and 2.
Posted 20th May 2011 at 13:47
notoriouslor
I really hope it's not the heater matrix, is this not a massive job to put right? I've still not had a chance to look at it, hopefully granny will watch the boy tomorrow and I'll get a chance, although I put some water in it right after work and it never p*ssed straight out. I've also bought a haynes today so I'll be reading through that but as you've all probably guessed I'm not exactly a mechanic
Posted 21st May 2011 at 01:39
Check out the FAQs as they are loads better than the haynes for most stuff.
Posted 21st May 2011 at 01:46
notoriouslor
Thought that just thought that the haynes would be handy to have as well
Posted 21st May 2011 at 02:05
notoriouslor
Bit gutted though, beginning to think I've bought a dog, nevermind you live and learn eh, anyone got a spare 3.0 v6 to drop in?
Posted 21st May 2011 at 02:17
cwspellowe
Someone on eBay is selling a V6 for £400 Wink
Bye bye Sundance Kid Sad
Posted 21st May 2011 at 02:22
notoriouslor
If only I had the cash mate, I'd be seriously tempted
Posted 21st May 2011 at 02:27
