Author Subject: URGENT help needed
Coming down the motorway, my car developed quite a loud tapping that sounded like an old sewing lacking it kept wanting to cut out but it held together till I got to my destination,
I put it down to the oil probably been spent
However turned it over to do some checks and it literally p*ssed oil everywhere prettymuch poored out like a fountain!
From the front of the block somewhere,
I've checked the radiator for oil but nothing that I can see,..
Any one any ideas :/
Here's some pix
Posted 17th May 2011 at 15:11
bennn
Is the oil filter done up tight, looks like thats where its spraying out of!
You wont have done it any favours driving it like that!
Sad
Cherry Red 306 HDI
Posted 17th May 2011 at 15:19
Another vote for oil filter and five years taken off the life of your engine Yes
Posted 17th May 2011 at 15:45
I've got it in bits it looks like the seal around the oil filter has given out! :-/
Will the engine be f*cked shortly then?
Posted 17th May 2011 at 15:49
MCH_GTi6
formerly mch
Dads work had a volkswagen that did that (common fault with that particular engine apparently)
They'd driven it 20 miles and it went again fine with fresh oil and a filter...
So with any luck yours may be ok...
Team Moonstone� Ph3 GTI6
Team Rallye
Posted 17th May 2011 at 15:52
If you're lucky it'll be just wear & tear damage, just make sure you've got a flushed it out properly before you drive it again.
Personally I'd get a new filter on, fill it with cheap oil, pump it through, drain it out then refill with decent oil, just to make sure you get out any crap that's in there.
Might be unnecessary, but better that than drive around with crap being scraped around the oilways.
Posted 17th May 2011 at 15:58
I'm on it now lol most of the oil is half way down the street now :-/ I'm off to Peugeot
And pugjim is coming to lend me a hand! Big grin
I only have a ikea tool box to do it all with lol
Posted 17th May 2011 at 16:08
MCH_GTi6
formerly mch
the fact there was still so much oil in it to come out when you stopped should of helped keep it a bit safer... I'd of been very worried if there was none when driving.
Team Rallye
Posted 17th May 2011 at 16:16
I had a very similar thing happen on a mk1 golf. Changed the oil filter and the seal blew out immediately when I started it. Oil fooking eveywhere!
Posted 17th May 2011 at 16:24
pugjim
Sad
Posted 17th May 2011 at 18:48
Well,....
It's spun a big end bearing and that's what the noise was
It had also blown the seal out from around the filter which didn't seem all that tight so weather that's contributed to it or not I don't know but well, joys of motoring
Mellow
Posted 17th May 2011 at 19:10
Should have stopped right there!!
Did you not see the low oil pressure light?....
Engine rebuild time...
Edit; if its spun a bearing then you'll need a replacement rod, possibly a crank if youre unlucky.
take it the sump has been removed if you know its spun a bearing? if not it might just be knocking.
Posted 17th May 2011 at 19:13
Oooh, nasty. Almost certainly it'd be the other way round - filter comes loose, oil pressure drops, bearing spins.
Nasty and unfortunate mate, I feel for you.
Posted 17th May 2011 at 19:12
Ahh thats proper shit news mate,should just buy my china and swap lumps over,simples! Thumbs up
Posted 17th May 2011 at 19:19
al4x
I'd be kicking the arse of whoever serviced it, new lump or break it
Posted 17th May 2011 at 19:20
pugjim
Sump not removed yet just the very loud bottom end knocking. Possibly spun a shell but will find out when engine is out. Just trying to make room for it on my drive. Got to jiggle round 2 transit vans, a 306 and a 207 LOL
Posted 17th May 2011 at 19:36
ben306
Mine spun a bearing 140 mile after rebuilding all the top end.
Be wary of buying bottom ends tho. I picked one up off Birk which turned out to be from a over heated engine, the pistons had started to melt.
Its meant that Ive had to do a full bottom end rebuild with a fresh crank and rod!
My 306 Rallye Project Thread
Lap of Anglesey Coastal
3 sisters circuit
Few laps at Blyton
Posted 17th May 2011 at 20:02
smithers
Unlucky mate, what were we saying about these cars being money pits at the begining of the month LOL
Good luck sorting it Thumbs up
1997 Black GTi6
smithers205 at hotmail.com
Posted 18th May 2011 at 02:07
Rich E Forum Admin
I've seen exactly this before. A piece of the destroyed bearing was fired through the oil filter which punched the seal out.
Posted 18th May 2011 at 02:45
pugjim
Big end failure no 4 cylinder (timing belt end) crank and rod are scrap Sad
Posted 18th May 2011 at 18:34
Nasty. 3 cylinders ftw!
Posted 18th May 2011 at 18:50
Same bearing went on my RFY lump in my ZX though it didn't scrap the crank, I stopped soon enough!
Posted 18th May 2011 at 19:25
ben306
Mine was flywheel end. Same, rod and crank no good.
3 sisters circuit
Few laps at Blyton
Posted 18th May 2011 at 21:25
greenbelt
Been there, done that Bored
Standard Black 6
Black HBSC6 Smoke
Posted 18th May 2011 at 22:38
well if it was going to go then,...
to be honest the noise started out like a bag or something stuck under the car then turned to an angry wasp/something vibrating which then suddely changed into an old sewing machine sound it never got any worse, but she did manage to limp to the intended destination, before giving up, Love
Picture from the other day LOL
Posted 19th May 2011 at 20:27
