Author Subject: Tapping after 6 months of no use *Vid Added*
rich999
Hi guys,
I have been reading all the posts I can about tapping engines, on this site and others, but none are the same as mine. The car has been parked up for 6 months now after it got a 2 page list of failures on it's MOT, and the birth of my first son slowed down my work on it. The car had a very quiet engine newly fitted with a Sabre Head, after a cambelt failure when I picked it up. But I came to start it today and it has a very noticeable tap coming from the top of the engine. (Oil level is fine)
So my question is how can a quiet engine, turn into a tappy engine with absolutely nothing being done to it???
I'm going to try and get a video of it tomorrow so I can get your opinions on it.
Posted 14th May 2011 at 21:06
matty_rallye
If its the usual head tap after a cambelt failure then theres no quick and easy fix. It will be down to poor head repair. Head will need to come off, poss bent valve / guide tapping. Thats the most likely thing, sorry.
2.1 16v 306 Rallye.
Posted 14th May 2011 at 03:19
allanallen
Dont panic!!!!! The Hydraulic lifters will have drained, take it for a good run and get the oil up to temp, it'll quieten down.
Facebook
Posted 14th May 2011 at 03:35
rich999
allanallen I really hope your right! As the car has no Tax/Test at the mo taking it for a 'run' is a no go. So how long would you leave it running if it was idling on my drive?
Posted 14th May 2011 at 03:43
knoxie
I also have a tapper, mines normally when it's warm not cold :s I have read a good few threads can't find anything to relate? Could it be the oil getting too thin?
ex S16 (K.I.A Sad )
GTI 6 Big grin
TEAM more scratches than an emo kid
TEAM BLACK
but wishing it was bianca white Sad
Posted 14th May 2011 at 03:48
matt evans
It you're 100% certain it wasnt a tapper before you laid it up for 6 months, then its more than likely a slightly sticky hydraulic tappet. Mine wasnt started for 4 months over the winter and it sounded like an old Ford CVH for the first 10 minutes.
Let it run for as long as it needs on the drive, then give it a fresh oil and filter change and it should be ok
honestly3k wrote:
owain wrote:
Posted 14th May 2011 at 03:54
cwspellowe
It's naturally quite a noisy engine due to the injectors anyway, but let it warm up as already suggested and once oil's circulating again it should quieten down.
If you heard the engine running before it was left standing and it was fine then, there's nothing could have happened to bend valves whilst it's been sat. More than likely nothing to worry about Smile
Bye bye Sundance Kid Sad
Posted 14th May 2011 at 03:58
allanallen
I highly doubt you've bent a valve or damaged a guide by not using your car,regardless of what the scaremongers would have you believe.
Start it up and hold it at different revs for a couple of minutes. Lifters tend to be noisy after being stood and they love decent Fresh oil of the correct grade.
Facebook
Posted 14th May 2011 at 04:00
allanallen
I recently bought a forum diagnosed 'tapper'. It tapped when it got hot, I changed the oil to the correct grade and it's quiet as a mouse even when the oils up above normal running temps.
Facebook
Posted 14th May 2011 at 04:04
cwspellowe
True, but it depends how hot the engines get too. If a valve is squiffy or the timing is slightly off, the expansion caused by the heat of a ragged engine can cause it to tap when the top end gets hot.
I think it was welshpug who said a valve opening and closing at up to 4000 times a minute becomes like an elastic band. If the clearance is minimal, it gets even less when the engine's hot and revved.
Posted 14th May 2011 at 04:30
Most hydraulic lifters do this if they drain over time and stick slightly, warm the oil up at a fast idle, usually once it's thinned out and the surfactants become active it'll clear whatever shit is in there and go away.
If so, drop the oil, replace with new and warm it up again and it should be gone for good.
If not, you might have to take it for a long drive to get enough heat into the engine to sort it out, but if it didn't tap before it shouldn't be a bent valve or guide problem.
Posted 14th May 2011 at 04:45
rich999
Cheers for the help guys! Here is a link to the video taken this morning (engine cold). What do you think
http://i257.photobucket.com/albums/hh215/Ghia999/f31399f0.mp4
Posted 14th May 2011 at 13:58
felixthecat
Any news on this, rich?
Have to say, mine sounded exactly the same after it had stood for around 5 months (only driven in summer). Did an oil change with filter and drove it a few miles and its quite again Smile. So maybe this should be the first thing to do.
306 Gti6 Cherry Red Supercharged Smile
Greets from Germany....
Posted 17th May 2011 at 03:19
