Author Subject: problem with my 6
bukosgti6
hi guys could someone confirm the problem i have.im driving along and all of a sudden it dies then kicks in after a few seconds it doesnt cut out im thinking icv cause other than the tps; i have changed every sensor it backfired once and its getting worse a trip to carls i think could anyone shed any light on this many thanks for your time
Posted 3rd May 2011 at 03:49
woody.
Ive got exactly the same problem, it seems to do it at the same point after leaving my house from work! Very strange.
Posted 3rd May 2011 at 16:11
Any of the following,
MAP Sensor
TPS Sensor
Crank sensor
Posted 3rd May 2011 at 17:17
mattgti6phase2
MAP Sensor
TPS Sensor
Crank sensor
^^^^^^^^ this! Thumbs up
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 3rd May 2011 at 19:52
Unlikely to be the crank sensor as they tend not to start. Check the wiring though.
Unplug the others and see if its any different.
Posted 3rd May 2011 at 22:05
pebbles167
Have you actually changed the sensors or just taken them of and given them a clean? This doesn't always work in my experience, especially the ICV and MAP Sensor. Id recommend forking out for a new one of each if you cant find the problem and if it still isn't sorted at least you know they are less likely to go wrong in the future.
2005 Peugeot 206 GTI 180
2008 BMW K1200R
Posted 3rd May 2011 at 22:23
mwl001
Mine did this and it was the lambda sensor
Posted 4th May 2011 at 00:02
anth
Can even be fuel pump.
Posted 4th May 2011 at 02:54
bukosgti6
thankyou for replys had new lambda and map changed a couple of mths ago and tps has been changed but not a new one.
Posted 4th May 2011 at 07:10
bukosgti6
sorted carl got an icv problem solved.another week of happy motoring
Posted 5th May 2011 at 00:15
bukosgti6
ok not done went down motorway today and it feels like im going over a cobbled road it does it at all speeds so its not the wheel balancing please help or im going to get rid after changing the icv its better because it doesnt die out but the car does not run as it should i have changed tps map and green sensors any advice apart from burning it.
Posted 7th May 2011 at 23:53
bukosgti6
any suggestions
Posted 8th May 2011 at 03:25
