displaying posts 1 to 25 of 43
Author Subject: understeer...
rallyeash
Firstly i know its not a 306, but as theres a good few knowledgable members on here thought it would be worth posting this up, ive started a thread on drivers about it also but wanted your suggestions aswell.
Im after abit of advise on my 205 rallye track car on the handling front. i feel like im getting to much understeer with my current setup, front seems to want to just push on when any slight power gets added. for the setup im running i think it should be much tighter...
suspension setup is
Front
205 gti subframe
205 gti arb
Gaz GHA coilovers
300lb springs
eccentric top mounts, set as far back and in as possible
Hispec ulralite calipers on 266mm discs (not suspension related but still unsprung weight)
Quiafe Atb diff
Rear
205 1.9 disc beam,
23mm Torsion bars
Gaz rear dampers
24mm ARB
rear beam was built by "Anthony" approx 2k ago and about 200 miles ago was checked over and the 23mm tb's added.
Wheels, S2 rallye steel wheels, 185 60 R14 toyo R888's, although will be dropping down a size to 185 55 R14 Yoko A048's which should have less sidewall flex and stop the rubbing on the rear arches when ive a passenger
colin satchell cage, full weld in job which goes through to the front struts, across from the front of the cage to the RH suspension turret then a built in strut brace between the turrets
running an iron block Xu10 engine
all suggestions welcome.
309 3dr K20 Type R
Posted 2nd May 2011 at 20:16
beez_neez_gt
Probly best to take 205 drivers forums advice tbh.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 2nd May 2011 at 22:29
So you are having 'on power' understeer rather than turn-in?
Turning both ways?
What are your current alignment settings and has the car been corner weighted?
I guess no spacers at all?
Front arb connected?
Tyre pressures?
Initial thoughts are soft front springs versus the back and weight distribution. Is it lifting the inside front wheel at all on power?
Posted 2nd May 2011 at 22:46
Why? There are plenty of people on here that have an idea about setting up a fast FWD car...
Posted 2nd May 2011 at 22:43
lotek
sounds like you need a LSD Thumbs up
try removing a droplink..
Posted 2nd May 2011 at 22:44
He's got a Quaife ATB if read it...Roll eyes
Posted 2nd May 2011 at 22:45
lotek
FOYC Thumbs up
alignment issues, increase Front wheel and tyre width, reduce front tyre pressures.
what kind of rake do you have on car?
Posted 2nd May 2011 at 22:53
tvrfan007
Sounds like you need an LSD that works. Quaife isn't particularly well regarded.
Not familiar with 205s, could you fit richw rollers?
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 2nd May 2011 at 22:54
rallyeash
Turning both ways?
Tyre pressures?
not been corner weighted.
arb connected
tyre pressures, set at 22 psi on the last trackday
well it just seems to push on rather than grip on turn in obviously the more power thats been put down the worse it is.
ive been out and measured the sill to floor heights, front is 145mm and rear is 160mm
also tried lock to lock and right it has a touch over 2 turns and left has under 2 turns. ive checked the tre's and theres more thread on one than the other indicating the racks not central.
first thing im going to do is centralise the rack and reset the tracking. was previously set to 0
309 3dr K20 Type R
Posted 2nd May 2011 at 22:55
Alignment settings...?
Posted 2nd May 2011 at 22:58
rallyeash
to be honest, i do like the quiafe diff and it does seem to help wheelspin alot but does allow abit of slip which gives abit of mechanical sympothy.
people who say there rubbish and didnt even make a difference are in my eyes clearly wrong. at combe, i can pull out of the two chicanes in third for esses and second at bobbies (abit tigher exit) with hardly any wheelspin. now a 205 with 230bhp and 750ish kg with an open standard diff would have heaps of wheelspin!!
309 3dr K20 Type R
Posted 2nd May 2011 at 23:01
rallyeash
were set to zero a while ago but hasnt been done for a little while. going to reset it once i try a centralise the rackSmile
309 3dr K20 Type R
Posted 2nd May 2011 at 23:03
rallyeash
forgot to add im running 309 arms and shafts so the front track is 20mm wider, also have solid beam mounts
309 3dr K20 Type R
Posted 2nd May 2011 at 23:05
allanallen
I'd try some more wind in the Tyres too, I run my 205 and 309 at around 30psi hot.
A bigger rear arb would be worth ago if you have one available, I realise not everyone agrees with using monster rear arbs but i like them.
As mentioned a plated diff would be a step in the right direction.
My track car runs 25mm bars/28mm arb, 500lb springs and 21mm front arb with a plated diff on 888s. If anything the back end is a little 'loose' but the diff allows you to correct the arse end. I'm not talking crazy lift off oversteer stuff just what you can feel through your backside.
This is on a 309 mind but may be good for comparison.
Facebook
Posted 2nd May 2011 at 23:14
rallyeash
they were around 30 psi hot from memory which worked down to about 22 psi when cold. i would run them on the road at about 27psi.
until this morning i had the standard 19mm tb fitted but fitted the shortened gti6 24mm arb earlier. on the way home it didnt feel any better or different if im honest, although could be better when out on track, im just about to book up for Llandow on the 21st of this month. Llandow being a tight technical track i want to try and improve it Smile
is a 28mm arb a straight fit or does it require some machining
309 3dr K20 Type R
Posted 2nd May 2011 at 23:21
allanallen
If your using standard 205 trailing arm pins you can get upto a 30mm arb in iirc.
Once you've centralised the rack I'd experiment with tracking aswell, perhaps a bit of toe out? My 205 was bas**rd to keep in a straight line under acceleration set at 0, probably because of the diff/torque but it now runs about 1mm of toe out, this improved straight line acceleration and it turns in a lot nicer, seems to grip better somehow. Feels a bit sketchy at high speeds though but I guess you can't have everything.
Are the rear arms standard 1.9 ones?
Facebook
Posted 2nd May 2011 at 23:38
rallyeash
ah cool, think i'll borrow the laser gauges from my brothers mate again and have another bash once i centralise the rack.
a touch of toe out could be what i require, when you say high speeds how high you talking?
probably the most i'll be pulling is around 120-125 up towards avon rise at castle combe.
yep standard 205 1.9 beam, 23mm tb's and 24mm arb
309 3dr K20 Type R
Posted 2nd May 2011 at 23:48
Step one as you say is to sort the rack and tracking out, you can't really start diagnosing other problems if there's something fundamental wrong.
Non-centred rack on mine made it wander all over the shop with the power on from the bumpsteer.
The spring rates shouldn't be an issue, the damper settings might well be though, what are they running at? Did you set them by winding out from full hard or from winding in from full soft.
Posted 3rd May 2011 at 00:02
rallyeash
they were adjusted back from hard, there in the middle of there adjustment. they feel about right on the road though.
does seem to wander abit on the road when powers on now you mension it
Smile
309 3dr K20 Type R
Posted 3rd May 2011 at 00:07
Well, if the rack doesn't sort it, try going harder two clicks on the rear and softer 2 on the front, see how that feels. Adjust back from hard like you are doing.
Posted 3rd May 2011 at 00:10
rallyeash
Thumbs up
309 3dr K20 Type R
Posted 3rd May 2011 at 00:15
allanallen
Now then Phil, what's the reason from adjusting back from hard on the shocks?
Ash, Probably 110mph+ it just doesn't feel as safe as usual. You get used to it though. It might be a bit worse round Combe with it being so bloody rough though Big grin
Facebook
Posted 3rd May 2011 at 00:17
Like most needle-type adjusters they run up against little o-ring and grub screw as the 'stop', which isn't very accurate - they can be open differing amounts when set wide open. Especially as they're a straight taper and not a progressive needle.
However, shut is shut, so if you close the adjusters on the all the dampers and then wind back from there, the settings should be a lot more accurate between them.
There'll still be a bit of difference as there's always some float and wear on a needle adjuster - that's why the same setting can be slightly harder if you hit it going one direction compared to going the other - barrel/orifice adjusters are more consistant and accurate, but are more expensive to make and bulkier to package.
Posted 3rd May 2011 at 00:43
Denis
Common ways to reduce understeer:
- Soften the front dampers / springs
- Stiffen the rear dampers / springs
- Raise the back
- Lower the front
- Disconnect front ARB
- Put bigger rear ARB
- Use wider front tyres
- Optimise front camber (to give optimal contact patch when cornering – use pyrometer to measure tyre temperature and tweak caster / camber to get uniform temperature across the tyre)
Cherry Red Rallye Project thread
WhiteBMW M140i
Posted 4th May 2011 at 02:14
More negative camber, more negative camber, oh and if you can, get some more negative camber Smile
Posted 4th May 2011 at 14:12
