I have:
Brand new in the box 4 x wossnor pistons and 4 x pec rods with arp bolts £600
A airesearch t3 turbo with A/R of 42 and 48 that will give 350 hp ( if you search airesaerch on the tinterweb u will see its a sister company of garret) the turbo was sent to turbo technics for a overhaul and the wastegate port was opened up by 1.5 mm, i have proof of the work and that the turbo is spot on!
With the turbo i also have the exhaust manifold that was made by ab motorsport and was tested on a friends gti6 turbo 205 and worked great, the down pipe is made in 2 parts for ease of fitting but will need the flange welded on the end to suit your exhaust system!
£1000 for the turbo, manifold and downpipe
I also had a oil supply line made by thinkautomotive with the correct ends for the engine and turbo, however i have not had a return made yet but that is easy!
I have a custom inlet manifiold made by a member of the turbo sport website who makes inlets for escort cosworths, it has had the throttle body relocated to the other side so less boost pipe is needed which in turn will give less lag!
The inlet was flow tested and produced even flow to the runners! £200
I have 4 new bosch 803 injectors that will be good for 300hp+
£150
i have a magnetti marelli 3 bar map sensor £30
A N70 boost solinoid valve £30
The conversion is based mainly escort cosworth parts apart from the boost solinoid valve as they are better than the anel valve used in the cosworths
4 bar fuel pressure regulator £30
Hdi gearbox for better ratio and higher top end £100
Kazz plate diff (second hand but only with 700 miles use so you dont need to run it in and waste £60 on oil) 5l of new oil included £450
Im in no rush to sell as im in afghan till the end of july so no silly offers plus if it doesnt sell i might have to have a 300hp front wheel drive 306 and a 400+ hp 4x4 306 but i dont think the other half will be happy!
Sorry no photos due to downloading takes ages out here but i have photos of the pistons rods, turbo, exhaust manifold and inlet on my gti5turbo project page!
pugheaven
Take it easy out there, stay safe.
