Author Subject: ECU self learning ?
beez_neez_gt
Hi,
Is the 306GTI6 ECU self learning ?
If it is will it work well enough to get the most out of using high octane V-power fuel ?
Cheers.
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 1st May 2011 at 20:27
cwspellowe
To an extent, yes. If you've been using 95 RON and switch to 97 or even 99 RON it'll take a few tankfuls to adapt but they have a built in margin for adapting air/fuel ratios to suit Smile
Bye bye Sundance Kid Sad
Posted 1st May 2011 at 20:47
smegal
beez_neez_gt wrote:
Hi,
Cheers.
Although mine seemed to run better on tesco99 I'd just use 95 RON. I doubt it is worth the few pence a litre extra.
Ex SC-6
Now in a Megane R26
Posted 1st May 2011 at 21:11
beez_neez_gt
I know when using the better stuff like V power the head tends to be cleaner on the inside, compared to using the usual unleaded.
I read somewhere the 6 has to be set up to take the high octane type of unleaded ?
Pug fee`ver,
Posted 2nd May 2011 at 02:28
v power for the win!!!!
Posted 2nd May 2011 at 02:55
lotek
youl find the owners manual says NOT to use high octane fuel Wink
but ive found using the tesco high octane on track lasts longer than regular fuel Yes
Posted 2nd May 2011 at 03:37
V Power etc seemed to last longer, but not enough to warrant the extra expense. The only one I used to use consistently was Waitrose 97 as that was only 3p more than the 95.
I'd have thought an ecu reset with a full tank of fresh V Power might make a difference, but we aren't talking turbo car difference. Guess it depends on if the ECU adjusts fuelling/advance on WOT as it doesn't use the lambda at that point iirc.
Posted 2nd May 2011 at 14:39
not certain how the ecu behaves on WOT, it would pick up knock/det and retard the ignition if there's not enough fuel going in on the WOT map.
thats my understanding of it anyway LOL
Posted 2nd May 2011 at 17:00
