pat
| Author | Subject: 406 btcc cams |
paddygti-6
Banned!Location: portsmouth Registered: 22 Apr 2011 Posts: 68 Status: Offline |
hi i have just built my gti-6 engine up with je forged pistons and steel rods it was bored to 86.5ml. i want to run 406 btcc cams or the biggest cam i can without solid lifters?? any ideas guys?? ________________________________________ pat |
rallyeash
look at the specs on the cat cams website. should say what you can and can't run. im running 109's in my engine. although i think you can run 110's on standard lifters________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
miles
Why use BTCC cams, there made to a regulation so you can get allot better for cheaper, and they would all use Solid lifters anyway.________________________________________ 306 Rallye Sptint/Race Car, 205 CTI 1.9 8v to name a fewRoad, Track and Race/Rally car preparation to your personal requirements, Full Workshop & Diagnostic Facilities New and Second parts, from Plugs to Turbo's We now also carry out Routine Servicing www.pugracing.com & FB Page, https://www.facebook.com/PugRacing Ebay; http://stores.ebay.co.uk/Pug-Racing-Shop 2012/2013/2014/2019 Class Winners at Gurston Down Speed Hillclimb & Joint overall, Class record too along the way, |
paddygti-6
btcc have very long duration and can make 240bhp________________________________________ pat |
rallyeash
not always best though, you will struggle to make 240 with a standard head.you can make 270+ on that bottom end with the right head, cams, solids etc ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
paddygti-6
i dont want to go solid lifters tho i aim to get around 220 bhp is that to much to ask of hydro lifters?________________________________________ pat |
rallyeash
im running 87mm pistons, 88mm steel crank, forge pistons, steel rods, cat cams 109 retaining standard head just with a small amount of work, 4 branch maniflow manifold, jenvey throttle bodies, 8 injectors, satchell inlet manifold, dta ecu and its approx 230 bhp ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
paddygti-6
iam getting manifold anyway. so i could run 110 cams and achive around that bhp retaining the gti-6 inlet that is a btcc one??________________________________________ pat |
rallyeash
just checked there website, requires "custom parts" where as the 109s are oem partsdon't get hung up on the "btcc" stuff, generally its overpriced when much better can be bought for cheaper. the "btcc" engine had to run inside regulations so were built to a tight spec, why would you want to build your engine to that? the inlets aren't all that either, again were devolped for regulations as a single t'b had to be retained. either way you will need an aftermarket loom, ecu and a proper mapping session ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
paddygti-6
well iam trying to build on a budget as do not have funds for itbs my head has piper valve springs in with retainers also i got them so i can get the bigest cam in before going solids??________________________________________ pat |
matty_rallye
Senior User Location: Devizes Registered: 28 Oct 2005 Posts: 966 Status: Offline |
I would suggest that the 109 catcams may be best for what you are looking for. ________________________________________ 2.1 16v 306 Rallye. |
miles
Also different cams need different springs to suit so another point to watch, No idea on Piper spec as I avoid them at all costs, the companies had more names than I care to remember which must say something Building on a Budget can be more expensive in the long term, ________________________________________ 306 Rallye Sptint/Race Car, 205 CTI 1.9 8v to name a fewRoad, Track and Race/Rally car preparation to your personal requirements, Full Workshop & Diagnostic Facilities New and Second parts, from Plugs to Turbo's We now also carry out Routine Servicing www.pugracing.com & FB Page, https://www.facebook.com/PugRacing Ebay; http://stores.ebay.co.uk/Pug-Racing-Shop 2012/2013/2014/2019 Class Winners at Gurston Down Speed Hillclimb & Joint overall, Class record too along the way, |
henrik c
Regular Location: Søllested Registered: 17 Jan 2008 Posts: 164 Status: Offline |
paddygti-6 wrote: hi i have just built my gti-6 engine up with je forged pistons and steel rods it was bored to 86.5ml. i want to run 406 btcc cams or the biggest cam i can without solid lifters?? any ideas guys?? What did you pay for those JE pistons? And what are the 1:10 or... ________________________________________ /Henrik C |
fatlapit
Location: STOCKSFIELD Registered: 02 Nov 2010 Posts: 3,040 Status: Offline |
86.5 is standard bore!!________________________________________ |
henrik c wrote: paddygti-6 wrote: hi i have just built my gti-6 engine up with je forged pistons and steel rods it was bored to 86.5ml. i want to run 406 btcc cams or the biggest cam i can without solid lifters?? any ideas guys?? What did you pay for those JE pistons? And what are the 1:10 or... You'll notice the chap is banned so won't reply. ________________________________________ ![]() |
GTI-6
Regular Location: Brisbane Registered: 18 Apr 2012 Posts: 163 Status: Offline |
how'd he manage that one? ________________________________________ Love thy 6 |
fatlapit wrote: 86.5 is standard bore!! No its not. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
fatlapit
Wel my 87 were one size overbore so ________________________________________ |
ryangti6
Seasoned Pro Location: Pontypool Registered: 01 Sep 2006 Posts: 1,839 Status: Offline |
Standard bore is 86mm________________________________________ Ryan |
Rich E
fatlapit wrote: Wel my 87 were one size overbore so One size for that manufacturer, but some do 86.5mm as an overbore size. Think about it... 86x86 = 1998cc, 86.5x86 = 2022cc ________________________________________ Rich |
Seasoned Pro Location: Southwark Registered: 18 Jul 2010 Posts: 4,865 Status: Offline |
Yup, Tis a perfectly square engine.________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
