Author Subject: jerking at start
specter
hey
i have got a problem with my gti6
when i release the clutch at low engine speed, the whole car is jerking
when i release it higher, theres no problem
what does this cause?
Posted 20th Apr 2011 at 22:01
Wrong section! Either vss sensor,clutch cable, bearing or akward driving
Posted 20th Apr 2011 at 22:06
Could be a warped/knackered clutch.
Posted 23rd Apr 2011 at 21:19
specter
to reanimate this thread
what can be wrong with the clutch cable?
i mean its more obvious that its a clutch fault isnt it?
aaaaaaand, if changing the clutch, which one? helix, omp?
as far as i know its a pulled one isnt it?
again, its only at start, between first and 6th gear gearchange theres no problem.
greets
Posted 20th Jul 2011 at 19:42
mattgti6phase2
Get an o.e valeo clutch most motorist centres stock them. As for the cable not much goes wrong if you have a stiff clutch then it's the fork arm bushes. Just give them a good clean when the box is out.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 23rd Jul 2011 at 04:45
paul_13
Sounds like clutch mate, get a new cable when changing the clutch and the fork arm bushes are cheap from pug. Worth buying.
205 GTI6- Rebuilt engine, lightened flywheel, lightened pulley, 307 hdi brakes, Koni struts on gravel spec springs, 22mm TB's, 24mm ARB, Roll cage, Citreon ZX rear dampers, SL434's, Xsara box, Quickrack, Pipercross enclosed induction kit. Smile
Private work, not a prob Smile
Posted 23rd Jul 2011 at 04:49
