Author Subject: 306 maxi suspension
mroccox
Hi!
I would like to buy maxi bodykit but I don't know what should I do with suspension. Please help me. Did someone see wide track conversion from dimma?
Posted 20th Apr 2011 at 00:16
lotek
wider wheels with different offset and circa 20mm hubcentric spacers.
or alternatively contact NUR motorsports and have a proper drive in drive out job done
Posted 20th Apr 2011 at 00:21
for proper Maxi bits you need lots of ££££.....
rear beam alone was about 15k euros...
alloy large bearing front hub carriers, long wishbones, longer driveshafts, direct to hub radially mounted brake calipers.
njo spacers required, though 18" motorsport wheels and a Maxi bodywork a must LOL
Posted 20th Apr 2011 at 00:24
marco gti6
I think you just smashed his dream of a wideboy 6 welsh LOL
Posted 20th Apr 2011 at 00:42
The maxi suspension is completely different from standard. It'd probably be as cheap to buy a car on the continent as buy the full suspension setup
Posted 20th Apr 2011 at 00:49
mroccox
wheels 8" ET0 + 20mm hubcentric spacers will be ok?
Posted 21st Apr 2011 at 00:42
It'll pull all over the bloody place.
Posted 25th Apr 2011 at 03:42
gtisid
ash has some mahhosive tyres under his 306 race car. better off buying a proper maxi from france for a reasonable sum of 20-35k. it would be cheaper unless you are a bespoke engineer and charge little for your time. wouldnt feel safe driving a car with all that shit hanging off the hub , spacers extensions for the wishbones,extended wheel nuts etc.
i too have dreamt of building a maxi replica,and there are a few of these home made ones about ...and they look damn cool but the real thing is so damn good it cannot be copied unless you have plenty of wedge
pugless
Phase 1 GTI 6 1996-1997
Subaru Impreza GB270 2007-2008
rare spiderman comics
same day international courier
Posted 26th Apr 2011 at 00:56
