Author Subject: Show me your....Forced induction foglight air intakes!
eddiebeano
Hi, I've done a search but I can't find out what the best size trumpet is to use for an air intake mounted where the foglight is, or how people mount them in the foglight hole.
I'll be looking to make a similar setup to Jokers clicky , but with the air feed going direct to the foglight.
cheers guys, Ed
team: Stealth Ninja
Posted 19th Apr 2011 at 07:01
that's how mines setup,
I'd go 76mm trumpet and try keep the ducting
induction vents all about this size,
76mm is the size of your throttle body anything smaller may restrict your air flow a little,
Posted 19th Apr 2011 at 07:18
eddiebeano
Thanks, that looks neat.How is the trumpet secured into the fog light hole though? and where did you get your trumpet from?
team: Stealth Ninja
Posted 19th Apr 2011 at 07:21
I used these Cerlik they have a ducting shop not far from me,
i'm sure if you ask them they'll have one in black
for the bottom of my viper to the fog I used,..
cerlick no2
then after lots of pushing shoving shouting and swearing managed to just secure an adjustable o ring clamp thingy around the ducting and tightened onto the trumpet Wink
Posted 19th Apr 2011 at 07:41
danny555
Gnrlee is the air intake pipe a 90 degree elbow? Plus did you have to cut it to size? One more question is that I have a green induction kit fitted to my standard intake pipe so will the 76mm pipe fit ok to my green cone filter?
1997 Black Phase 1 306 GTI 6
Posted 21st Apr 2011 at 00:47
yeah it's a 90 Degree 76mm alloy pipe,
it should pop on the end of the pipe without too much pressure,
it's not necessary but I did trim mine a little just to raise the Viper up as high as possible to try and keep the intake pipe from catching speed bumps, Dry
Posted 21st Apr 2011 at 07:24
Make sure you dont route the air ducting under the slam panel..
oops
Posted 21st Apr 2011 at 13:58
LOL ohh dear!
yeah as it is I'm going to have to find some way of protecting the bend at the bottom of the ducting i'm not liking it being exposed Unsure
I don't run an undertray!
Posted 21st Apr 2011 at 17:02
danny555
Cool thanks for the info mate. I will look into it.
Posted 22nd Apr 2011 at 02:29
can always show you my set up if you like mate. only down the road from you.
good protection tip..............duct tape lol works for me
Posted 22nd Apr 2011 at 03:50
danny555
Yeah mate that sounds like a plan. Could do with some good ideas and see what I can do with the car.
Posted 22nd Apr 2011 at 04:33
mattgti6phase2
IMO the best way to feed your car with air is to keep it the way pug intended it to be and then just adapt it Big grin
I run the standard box and cold feed set up with a green cotton replacement filter (dry) without that terrible oily stuff filters come with.
I then welded a a stainless sleeve into the top of the airbox which meets the snorkel pipe. This makes it completely airtight to the point that you can feel it drawing air even on
idle.
I also removed the smaller resonator box that sits to the side of the main airbox and put a bung on to cover the hole.
The last thing left to do is cut a rectangle out of the snorkel just above the grill which will force the air in as you drive.
Hope this helps I find it really works Thumbs up
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 22nd Apr 2011 at 13:04
aaron6
That's similar to mine except i use a k&n replacment filter and haven't modded the snorkel. It does have the resonator removed and welded up. It works much better than having an open filter set up. Smile
Posted 24th Apr 2011 at 15:18
mattgti6phase2
I think this to and by doing this its still the same as how pug built it which IMO is the best way. Why spoil it with a pooey induction kit Huh?
5 x a 306 owner!
Posted 24th Apr 2011 at 22:27
I see no examples of forced induction so far LOL
Posted 25th Apr 2011 at 01:52
lewisdmz
What's with cutting out the resonator? I thought that was there to pulse air at a frequency to match the inlet or something? Pretty sure it must have had a (beneficial) purpose?
Posted 25th Apr 2011 at 02:35
Its there to shut it up iirc.
Posted 25th Apr 2011 at 03:10
mattgti6phase2
^^^^^^^ Thumbs up
5 x a 306 owner!
Posted 25th Apr 2011 at 05:00
vipergti
Got to say was looking to sort out the induction on mine as car is totally standard at the mo and was planning to take out a fog but like the idea of just adapting whats there now, is there a noise change like when fitting a K&N induction kit or does it sound pretty much the same as standard Happy
Proud Member Of Team Astor
Posted 28th Apr 2011 at 00:49
mattgti6phase2
You can definitely hear it sucking air. It's just not a low booming sound like an induction kit. I personally hate the sound of open induction kits. Induction kits on the whole are pointless and do nothing other than drink more fuel, suck in warm air and sound terrible.
The above mentioned costs nothing to do and you can do it yourself. The only thing you need to really change is the filter for a cotton replacement.
Other than that the only induction kits worth anything are the viper ones which are enclosed and have a good cold feed supplied.
5 x a 306 owner!
Posted 28th Apr 2011 at 13:02
