Author Subject: gti6/VTS down pipe
JWP EFi
Turbo Legend!
Hi all, i have bought an 6 engine from a 2002 xsara vts, the exhaust manifold doesn't have the usual oval shaped flange to bolt the down pipe to, instead it has a flared fitting (the same idea as the mid to back box flared joint)
will a xsara front pipe / cat join up to the 306 mid section?
also, any ideas where i could get hold of the corrosponding flare thats on the vts front pipe?
cheers
Posted 16th Apr 2011 at 20:12
smegal
I'd buy a GTI-6 manifold to dodge the issues.
Ex SC-6
Now in a Megane R26
Posted 16th Apr 2011 at 20:47
as above!
if you have a look in the exhaust catalogues and see if the Phase 2 vts centre section is the same part number as the phase1, then there's a fair chance you can use the V-Band type manifold and downpipe in a 306.
if the part number differs, suck it and see!
Posted 16th Apr 2011 at 21:22
The 2002 model has two lambda sensors and a totally different manifold.
Posted 17th Apr 2011 at 01:02
tvrfan007
The manifold isn't "totally different" it just has a different cat connection, designed for a V band instead of flanged. My Rallye engine is from a 2002 twin lambda VTS so I just swapped manifolds.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 17th Apr 2011 at 01:24
JWP EFi
Turbo Legend!
appreciate the info chaps, i have compared my manifold to a friends 'flanged' gti6 one and they are identical other than the flared fitting.
think i will take the advice and just buy a proper gti6 manifold
cheers again for help
Posted 17th Apr 2011 at 03:35
JWP EFi
Turbo Legend!
anyone got a spare manifold kicking about in exchange for a few beer tokens??!
Posted 17th Apr 2011 at 03:38
