| Author | Subject: team pro 1.2 wheels |
brett cullen
Newbie Location: diddillibah Registered: 27 Feb 2011 Posts: 2 Status: Offline |
hi iam new to the forum i have a 1997 gti6 i race and i have done a search but want to make 100% before i order my new wheels because they will have to come all the way to australia , what et do i need to fit over brembos off a 406 coupe , for 16 x 7 team pro 1.2 wheel any info would help thanks |
velar
Regular Location: swindon Registered: 04 Jan 2009 Posts: 448 Status: Offline |
I run et15, this seems to be the norm.________________________________________ L reg "black and blue" phase 1 track 6 |
russbez
et15 sounds right iircwelcome to club ![]() ________________________________________ TEAM HIGH BOOST SUPERCHARGED RALLYEMy Rallye project thread |
cosmic spanner
Moral objector Location: North London Registered: 11 Oct 2004 Posts: 10,399 Status: Offline |
One thing to note, though - if you buy/source them direct from Rimstock you can get them with the centre bores direct-drilled for a 306, as opposed to many of the sets I've seen on here which seem to use plastic spigot rings. (These can melt on trackdays).________________________________________ Democracy is two wolves and a lamb voting on what to have for lunch....Liberty is a well-armed lamb contesting the vote. Project é - my 306 project thread. |
brett cullen
thanks for the info , when i get the wheels i will post some pics of them on the car |
velar
cosmic spanner wrote: One thing to note, though - if you buy/source them direct from Rimstock you can get them with the centre bores direct-drilled for a 306, as opposed to many of the sets I've seen on here which seem to use plastic spigot rings. (These can melt on trackdays). has anyone actually melted their spigot rings, or is this an urban myth. ( I think most are made from a hard plastic that will acually burn ( or at least boil)before they melt. I would suspect all the grease will have been burnt from my hub bearings and ball joints before the spigot rings give up ________________________________________ L reg "black and blue" phase 1 track 6 |
cosmic spanner
velar wrote: has anyone actually melted their spigot rings, or is this an urban myth. ( I think most are made from a hard plastic that will acually burn ( or at least boil)before they melt. I would suspect all the grease will have been burnt from my hub bearings and ball joints before the spigot rings give up Yep. Last time at Oulton Park, one of the other guys there - Jeffers maybe? - was effing and blinding at his Pro Race 1.2s as the spigots had begun to melt (OK I didn't do a materials analysis myself, but that's what he said had happened) and he couldn't get the wheels off. Mine and Ash's were fine (same wheels, but direct drilled). Just something to keep in mind. ________________________________________ Democracy is two wolves and a lamb voting on what to have for lunch....Liberty is a well-armed lamb contesting the vote. Project é - my 306 project thread. |
velar
hmmm so it's not an urban myth better keep a close eye on mine then!! thanks________________________________________ L reg "black and blue" phase 1 track 6 |
ravemercer
Regular Location: kent Registered: 18 Jan 2009 Posts: 422 Status: Offline |
ET15Apparently Rimstock charge about £5 per wheel for correct bore they stock bare cases with a 53.1mm bore re bore pcd/stud bore and paint then sell Two week wait mind but worth it I finks Cant wait to get mine 1 week to go. Toyo R1 R |
velar
Or you could use alloy spigot rings on 73.1 bore wheels (these bad boys won't melt.)![]() ________________________________________ L reg "black and blue" phase 1 track 6 |
