Author Subject: Black and Blue track 6
velar
Winter project is ready for it's first outingSmile
It's an L reg XSi with a full welded in cage by X-Sport Racing. Running a standard gti6 engine with jenveys and a DTA e48 ecu.
Posted 9th Jun 2011 at 18:41
velar
Had it's shake down at Hullavington airfield, then Stuck a much needed oil cooler on for Castle coombe last friday.
Suffering a bit of fuel starvation up avon rise, with less than ¼ tank, so swirl pot is next!!
Also need an LSD as it was really spinning up out of the chicanes.
Posted 14th Apr 2011 at 17:21
velar
Does this look to have to much rake?
Posted 15th Apr 2011 at 15:37
Do you have the Jenvey's fitted yet? Smile
Posted 15th Apr 2011 at 16:43
velar
Yes it's running 45s on a standard engine, and sound lovely. The jenveys are daveyboys old ones as yours are are on my 406 coupe Cool
Posted 16th Apr 2011 at 03:18
re-rake, depends whether that's under braking or sideways weight transfer, and what rear dampers you're running.
though if it handles fine, leave it as it is, maybe raise the front a little.
what's the spec?
edit, thats just over avon rise I think? which is where most frotn engined cars get VERY light on the rear end, so I'd not use that pic to gauge rake LOL
Posted 16th Apr 2011 at 03:23
rallyeash
just noticed your only local Smile
yeah looks as if its over avon rise, not the best pic for judging rake. i know some of the saloon cars in the championship lift the rear wheels coming over avon rise with heavy braking. (nick charles 106 does it)
309 3dr K20 Type R
Posted 16th Apr 2011 at 03:26
velar
Fair comment on the picture,have added one on the trailer
I think you are right and the front is a bit to low (running spax front struts on standard mounts, and unknown coils)
Has 21mm tbs hybrid arb and Gaz gold rear shocks.
The car handles quite well, but does go loose at the back in the chicanes.
(P.S running your old gearbox, that struggles with 4 to 3rd till the oil heats up.)
Posted 16th Apr 2011 at 03:36
rallyeash
front could be a touch low but only would raise it a few mm.
most cars ive driven/ followed through the esses and bobbies go abit light on the back end. just keep your foot in it Thumbs up
309 3dr K20 Type R
Posted 16th Apr 2011 at 03:47
velar
Thanks for the comments, did have a very sideways moment at the esses, but looking at the video, I did pussy out of the throttle a bit Cool need an LSD really
Posted 16th Apr 2011 at 03:52
rallyeash
yep a decent diff will make the world of difference.
309 3dr K20 Type R
Posted 16th Apr 2011 at 04:04
velar
Going to fit a KAZ diff to this car, what is the easiest way to fit it, or does the box need to come out.
Fitted spherical top mounts, ( with the half moons bought from this forum)
Had to modify the top mounts to allow maximum camber adjustment.
Had to use a threaded top hat and half nut to mount the strut into the top mount, as the strut did not have a long enough threaded section.
Also machined some alloy spigot rings, after reading that plastic ones can melt on track!!
Posted 9th Jun 2011 at 02:02
matty_rallye
Looks good! You at combe this sat?
2.1 16v 306 Rallye.
Posted 9th Jun 2011 at 02:16
velar
Not really a fan of action days, might go and watch though.
Will you or rallyash be there
Posted 9th Jun 2011 at 02:20
rallyeash
yeah me and the brother will be there, got 4 sessions booked. im normally not a great fan of action days but the classic day doesnt seem to attract the same crowd
309 3dr K20 Type R
Posted 9th Jun 2011 at 02:24
matty_rallye
Usually the sports and classic action days attract a less chavvy crowd. Thats the hope again this year anyway!!
2.1 16v 306 Rallye.
Posted 9th Jun 2011 at 02:44
eddy_gti6
Looking good, lets see some engine pics and get a spec of the car up Thumbs up
Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url &amp; =
Posted 9th Jun 2011 at 06:32
velar
Spec is:-
Fully stripped Lreg XSi shell witha multi point weld in cage, by X-Sport racing. Cage is similar to the custom cage design, and has gussets on the A and B posts as well as the center above the windscreen. It is stitch to the roof and seat box. Extended to the front struts
Standard GTI6 engine with jenvey TBs,(daveyboy's old setup) and a DTA Ecu.
Brembo (406 Coupe) front calipers with Xantia V6 288mm discs, mintex F6 pads
AP racing 2 pot rear calipers with RS focus 280mm solid rear discs, standard pads. ( bit over braked on the rear to be honest, but should work well with the Alcon 305mm front discs that I am working on at the moment)
Hydralic handbrake and wilwood brake bias adjuster.
Fully welded front subframe, with Gaz gold struts (415lb springs) and solid top mounts.Roller bearing wishbones, and custom adjustable strut brace.
Solid rear mounts and GAZ gold rosejointed rear shocks.Hybrid ARB and Xsara VTS TBs
Custom wiring, with circuit breakers.
AFR and oil pressure guages, mocal oil cooler
Sparco winged seat
Black, Vittess tuning's, single skinned bonnet and tailgate. Polycarb fixed side and rear windows.
Lightweight battery located behind non existant passenger seat seat
Single wiper arm ( using rear wiper mech)
16inch pro race 1.2 with 195/50/16 a048s
race alternator with single grooved lighweight crank pully.
Modified 1.4l 306 front bumper with extended splitter
Rear bumper cut away for a venturi ( ongoing project)
Phase 2 front conversion ( as I could not wait for a phase 1 fiberglass bonnet!!)
stripped out dash, fan retained but heater matrix etc removed.
Pics
Posted 9th Jun 2011 at 19:48
Looking spot on, I placed some big orders today for parts and am hoping to have it ready for the end of the year.
Posted 10th Jun 2011 at 00:47
eddy_gti6
Quality build you have there mate Thumbs up Whats next after the brakes?
Posted 10th Jun 2011 at 06:45
velar
Thanks.
Got a high compression engine and some 285 cams to go in next, and will fit my kaaz diff at the same time.
Need to sort out the fuel system first though, as I get a bit of fuel starvation if I run much less than 1/3 tank.
Posted 10th Jun 2011 at 15:10
Cracking build Paul Cool
In regards to fuel starvation, think this is common with phase 1's as I know Chris Pellowe had issues Yes
Are you going to upgrade to phase 2 system (i dont know what is different) or just run a fuel swirl pot?
Posted 10th Jun 2011 at 15:50
velar
I had heard this about phase 1s so I used a phase 2 tank/pump and fuel lines!!!
Will probably fit a swirl pot, using the existing tank and pump, then a walbro type pump after the swirl pot ( like rallyeash has on his 205 build rallyash fuel pump etc
Posted 10th Jun 2011 at 17:03
