Author Subject: Trailing arm shaft wear?
MCH_GTi6
formerly mch
What should I look for on the trailing arm shafts in the way of wear?
Pulled some arms off a beam I have and there is slight pitting but its NOT where the bearings sit.
and by slight I mean you need to almost bash yourself in the face with the shaft to see it LOL
but what else should I look for? as they look quite mint to me
Team Moonstone� Ph3 GTI6
Team Rallye
Posted 17th Mar 2011 at 21:56
From the FAQ:
Good:
Bad:
Posted 17th Mar 2011 at 22:30
davedgti6
Sometimes the needle rollers wear into the shafts leaving small indentions that you can feel with your fingernail (and see), I have a shaft like this although I believe you can get the shaft pressed out, turned 180 degrees and then pressed in again, this leaves the weight of the car bearing on the good part of the shaft,
Probably better to get a new shaft though if the shaft is like this although I see no reason why this would not work, (awaits flaming from beam builders on here
LOL )
Posted 17th Mar 2011 at 22:41
MCH_GTi6
formerly mch
ah mine looks very much like the "good" example and nothing like the bad lol...
There is no wear around where the bearings sit so I assume there good Big grin
Team Rallye
Posted 17th Mar 2011 at 22:46
A little wet and dry if not pitted and your all good
Posted 18th Mar 2011 at 00:18
stick a picture up, soon tell, but any polishing isn't good really as that's where it starts the indentations, if you catch it where it is polished but has not yet made indentations then as mentioned you can get them turned 180 degrees (pressed out then back in) but if there's play then its a no-go.
Posted 18th Mar 2011 at 02:47
