Author Subject: shaking
mike rallye
hi guys, since i had changed me clucth and fitted a lighten flywheel i have notice when i start up the engine shake for the first couple of mins.then it is ok.
you would swear it was something like a misfire,but it is not misfiring at all and runs sweet . is this fault normal after fitting a lightened flywheel.?
the engine mounts are all ok to
any advice would be helpful
Posted 16th Mar 2011 at 00:13
walker_texasranger
What Fuel are you using? Shell V power by any chance?
Hilux InvincibleX daily
306 No.13 Doh
Posted 16th Mar 2011 at 00:27
mike rallye
no not v power. am using the normal unleaded fuel from shell.
Posted 16th Mar 2011 at 01:11
1.6306
did you change the thrust bearing? ive had a car in the past where the thrust bearing was starting to go bad and did what yours is doing
Posted 16th Mar 2011 at 04:41
Michael J Fox hiding in the engine bay? Dunno
Posted 16th Mar 2011 at 04:46
mike rallye
yes i replaced the thrust bearing on it to ,as it is pull type clucth.
last i known michael j fox wasnt in the engine bay
Posted 17th Mar 2011 at 00:44
monkgti
i notice mine does the same, not since changing the flywheel but the whole time, when the car is idling you can see the engine slightly juddering as if theres a miss but its not missing and drives perfect, its been like it since i got the car and since then ive had the head rebuilt and ne t-belt anadd but no difference before or after so i just put it down to one of the characteristics of these engines Roll eyes
IF YOU CAN READ THIS IM STILL IN 5TH!!!
Posted 17th Mar 2011 at 16:04
