Author Subject: Ball joints
mcfc1987
Morning all, I have a knock and some play in my wishbone bush, so I am removing my wishbones with Rich_W bearings and swapping them with some wishbones with nearly new standard bushes while I get the bearings sorted in mine. Can I re-use the ball joint as these aren’t that old. If so can you leave the ball joint in the hub and undo the bolts holding it to the wishbone, and just attach the new wishbone or can you remove the old wishbone with ball joint attached and swap over the ball joints off the car.
Thanks!
Posted 14th Mar 2011 at 15:51
Hi mate,the wishbones come with balljoints already fitted Thumbs up
Posted 14th Mar 2011 at 16:00
mcfc1987
bonus!, although are they 18mm?
Posted 14th Mar 2011 at 16:15
Yes believe so mate
Posted 14th Mar 2011 at 16:20
mcfc1987
cheers
Posted 14th Mar 2011 at 16:31
smegal
You could re use them as well, if you needed.
Ex SC-6
Now in a Megane R26
Posted 14th Mar 2011 at 23:06
