displaying posts 1 to 25 of 33
Author Subject: Mintex 1144 or DS2500's?
samjl
Need some new pads, and having a search, these two are the most reccomended!
Its for a Ring trip and need I want something that doesn't fade and has a decent feel. If the Mintex will last 2 laps of the ring at a time without Fade then I will go for them as they are much cheaper!
Posted 5th Mar 2011 at 06:15
SteviePut
DS2500's. Smile
Posted 5th Mar 2011 at 14:23
gtisid
i am just about to have my mintex s taken out from my scoob as they are just too hard and are no good for local driving. I have had both sorts in the gti6 and liked the feel under foot of the mintex 1144 s. I had the ds2500 before and they work fine, although you can only buy them a ferodo main dealer now and that makes them very expensive now.
too the point where the price put me off
pugless
Phase 1 GTI 6 1996-1997
Subaru Impreza GB270 2007-2008
rare spiderman comics
same day international courier
Posted 5th Mar 2011 at 16:35
SteviePut
The DS2500's are only £50 in my fitmentWhistle
Posted 5th Mar 2011 at 17:01
samjl
Are these discs any good?
http://cgi.ebay.co.uk/306-GTi6-GTi-6-Drilled-Grooved-Brake-Discs-Front-Rear-/120408620600?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c08e9be38
Just ordered braided lines. My discs are knackered, and these seem cheap for what they are. Probably be mated to 1144 Mintex front pads and some cheap rear pads that still do the job.
Also, what fitment is £50??
Cheers, Sam
Posted 5th Mar 2011 at 21:10
SteviePut
Just get standard discs Sam. IMO grooved discs are a waste of money and will likely crack if you give them deathSmile
Posted 5th Mar 2011 at 22:31
ant_kernow
quote:
Unsure
team umpalumpa.
Posted 5th Mar 2011 at 22:47
cooper666
with a bit of modificationLOL
clio r27
ps3 id:cooperkloe
Posted 5th Mar 2011 at 23:41
+1
Brembo standard replacements from gsf
Posted 6th Mar 2011 at 00:00
samjl
How do you get DS2500's for £50?
Posted 6th Mar 2011 at 00:04
cooper666
for wilwoods mate
clio r27
ps3 id:cooperkloe
Posted 6th Mar 2011 at 00:10
Rich E Forum Admin
The ones he's referring to are a Wilwood 4 pot fitment.
I've used grooved discs from the eBay seller you linked to and they were fine. I'd stay away from drilled though, as they do crack around the holes as said. Grooved discs help the initial bite on DS2500's too, but the cost is an increased pad and disc ware rate.
Posted 6th Mar 2011 at 00:13
SteviePut
It is for the Wilwoods I paid £50 ish for the DS2500's. Much better pads than the "Smart pads" I had initially.
The brakes C/W hoses, brackets and what ever's left of the pads maybe available when I come to sell the car as I'm likely to put it back to standard and sell the good bits separately.
Posted 6th Mar 2011 at 20:12
kit
Mintex 1144's or even 1155's if you are using the car for fast road use. Track/serious stick, use DS2500's. Standard Brembo vented discs will be fine for either scenario.
Racing driver, fighter pilot, astronaut, compulsive liar.
Posted 6th Mar 2011 at 20:21
allesclar
grooved also are more likely to warp like f*ck, like mine sadly Sad
will be using standard brembo discs with DS2500 next change Smile
Team allesclar ®
lotek
ds2500 last forever but outright braking power isnt as good as the mintex.
when the 1155 on rallye die ima try the yellowstuff or RC6 Devil
Posted 6th Mar 2011 at 20:50
Rich E Forum Admin
Nope, I've run several sets of grooved discs all with uprated pads and none have ever warped, even when given serious abuse.
I'm not a big believer in 'warped' discs. Pad build-up on the discs and uneven wear are much more likely to be the culprit behind vibration under braking.
You'd have to get the discs to an astronomical temperature to actually warp them through normal use.
Posted 6th Mar 2011 at 21:22
chrisd306
I've got f6rs for mine £175 for the kads!!
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 6th Mar 2011 at 21:30
maddriver9
i've got gti 6 brakes with 1155's and brembo disc's on my 205 and ive warppped the disc's. i did have 5 heads in an the car was taking serious abuse but am contemplating weather to skim the disc's up or buy sum grooved disc's?
178bhp 205gti6
¼ mile in 14.2
Posted 6th Mar 2011 at 21:36
Rich E Forum Admin
That sounds much more likely to be pad build-up on the disc. Using a sintered pad such as the Carbone Lorraine's would probably bring them back but if you don't have a set already it would be cheaper to just get new discs.
Posted 6th Mar 2011 at 21:42
samjl
OK, so the best thing to do is stick with the standard Brembo discs as apposed to the MTEC Grooved discs. If I went MTEC I would go for Grooved/Dimpled and not the drilled discs.
Does anyone know if you can get Performance Friction pads for a GTI-6? Got them on my bike and my other track car and they are amazing.
Whats the cheapest place to get Brembo's and DS2500's by the way?
Posted 6th Mar 2011 at 22:18
allesclar
that could be the problem them, can you get pads skimmed???
Team allesclar ®
Posted 6th Mar 2011 at 22:23
samjl
Does anyone know the cheapest place to get 2500's from online?
Posted 8th Mar 2011 at 16:10
Rich E Forum Admin
Will probably be Demon Tweeks if they still offer forum discount. Look in the Exhaust section for the guy offering the Magnex decats and give him a PM.
Posted 8th Mar 2011 at 16:19
samjl
Are the ones I want FCP565H?
I've had Ferodo's before, and they were bloody good. Don't fancy splashing out on Carbone Lorraine and Performance Friction don't do pads for the 306 so my next best bet is probably Ferodo DS2500's.
Posted 8th Mar 2011 at 16:34
