Author Subject: valve adjustments
1.6306
hi, would anybody know how hard it is to adjust the intake and exhaust outlet valves on the engine, i can take it all appart to do this and know the spacings for the valves but dont know what i have to do to actually adjust them?
thanks for any answers
Posted 2nd Mar 2011 at 16:40
They are self-adjusting.
Posted 2nd Mar 2011 at 19:24
Or are you thinking of adjusting the cam timing?
Posted 2nd Mar 2011 at 21:24
davedgti6
Is this on the 1.6 Tu engine?, if so they can be adjusted -best looking in a haynes manual, there is no adjustment on the Gti-6 engine
Posted 3rd Mar 2011 at 00:11
mattgti6phase2
I think your assumption of it being the tu is right as his user name is 1.6306 Big grin
If it is the tu then +1 to what you said.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 3rd Mar 2011 at 01:44
1.6306
hi thanks for the replys yes its the 1.6 tu5 engine, the valves sound like they need adjusting and since its 14 years old now i thought its time that they got done, i watched some youtube clips but coudn't fine a video of a peugoet engine being done
Posted 3rd Mar 2011 at 19:18
Same as an old a-series engine - undo the 13mm locknut on the adjusters, and then adjust them using a screwdriver until the clearance is right.
Piece 'o p*ss, 30 minute job if that.
Posted 3rd Mar 2011 at 19:25
1.6306
have you got to rotate the crankshaft pulley to move the cylinders and do the valves in their firing order or can i do them all in one go?
and how do you tell when the cylinder is up far enough to adjust the valve
thanks for reply
Posted 3rd Mar 2011 at 23:44
haynes manual FTW.
Posted 3rd Mar 2011 at 23:46
davedgti6
thanks for reply
To be honest if I where you I would take the car to a garage to get it done, they would only charge labour of one to two hours, its not a hard job, but like anything if you have not done one before then you could struggle, unless you read and understand how to do it by reading the section in the haynes manual,
Posted 3rd Mar 2011 at 23:59
I'll be down your way next weekend if you want me to show you how to do them, but it depends if I have time.
Posted 4th Mar 2011 at 03:56
you got your passport ready Phill?
Posted 4th Mar 2011 at 04:33
You only need that to get back into civilisation when you leave.
Posted 4th Mar 2011 at 04:57
1.6306
hi, thanks for the offer but i took a risk and done it today evrything went fine and was pretty easy, took me about 1 hour taking my time not to go wrong, thanks to evryone for replyingSmile
Posted 5th Mar 2011 at 00:47
