Author Subject: 406 brembos under cyclones
r4ly j
Sure some1 hAs tried it on here, where do they fowl?
On the back of the spoke or the inside of the wheel?
Any help plz,
Posted 2nd Mar 2011 at 12:21
Back of the spoke I seem to remember.
Posted 2nd Mar 2011 at 12:34
r4ly j
Cheers, do you know how much by??
I have spaced my cyclones out slightly to miss my coilovers and am running camber so shouldn't have any arch clearance problems?
Posted 2nd Mar 2011 at 14:11
Rich E Forum Admin
20mm spacers needed for cyclones & 406 brembos.
Posted 2nd Mar 2011 at 14:53
Infinitely better to just get some aftermarket alloys that clear them IMO Yes
Posted 2nd Mar 2011 at 15:37
r4ly j
Or use rotors with bells and space the caliper back 20mm, that could work. What's the thickest disc brembos could take??
Posted 2nd Mar 2011 at 15:46
28mm IIRC.
Rotors and bells would work, but it'll cost you.
Posted 2nd Mar 2011 at 15:48
r4ly j
I'm pretty handy on a lathe so will make bells no probs, been looking for a couple of months now at braking options and found loadsa 280&300mm rotor for around £100 just need to find some serious pads now, cheers for the replies by the way
Posted 2nd Mar 2011 at 15:55
lotek
Hmm 20mm spacers, Brembos and C5 Alloys Devil
Rich E Forum Admin
That'll be a really tight squeeze. You would need to use a 8" PCD rotor so the ball joint could sit inside it otherwise you won't get the inward movement you need. That then creates another issue with the calipers - can they move outward enough to give you the space to use that sort of size rotor?
Posted 2nd Mar 2011 at 16:26
jam7922
Would longer wheel bolts be needed with 20mm spacers for cyclones & 406 brembos?
Posted 3rd Mar 2011 at 02:31
rallyeash
yep, easier to go stud and nut conversion.
309 3dr K20 Type R
Posted 3rd Mar 2011 at 02:34
For 20mm I wouldn't use anything but hubcentrics unless you like your wheels falling off No
Ash's suggestion would be best if you're going with standard spacers though.
Posted 3rd Mar 2011 at 02:48
smegal
At 20mm I'd go bolt on spacers.
Ex SC-6
Now in a Megane R26
Posted 3rd Mar 2011 at 03:29
r4ly j
Well mite go for 15s or 16s then amd keep standard brake setup, I have got 20mm hubcentric spacers and longer bolts to try but maybe be selling my cyclones then MINT refurbed last year by pristine in satin gloss black.
Posted 3rd Mar 2011 at 04:17
To be honest unless you're doing track work, standard brakes (albeit with better pads) are the way to go.
If you're cooking them on the road, then you're obviously driving like a tool anyway and better brakes are going to give you false confidence and you'll crash and die and the world will explode.
I'd stick with standard brakes and have some nice wheels and no stupid squeal every time you fart on the middle pedal Yes
Posted 3rd Mar 2011 at 12:30
velar
Big grin Big grin Big grin
Posted 3rd Mar 2011 at 23:42
