Author Subject: Suspension Boffs!
iplay
I have been slowly adjusting the rear beam over the last year in half turn adjustments using a dummy shock (<c.2mm).
I wanted a little more turn in on the tight B roads. Yesterday I increased the dummy shock by 1 turn and the suspension went from taking corners at any speed without roll to a car which feels like a pram.
I can't believe that raising the rear by such a small amount can make such a huge difference to the handling. Is this due to not resetting the toe in?
Posted 28th Feb 2011 at 15:14
lotek
the toe wont affect roll.
you sure the ARB plate bolt hasent snapped?
Posted 28th Feb 2011 at 15:44
Rear ride height does affect the castor and toe in at the front, and the rear roll centre doesn't move with the height either, so the car's are quite sensitive to it, especially with the damper ratio back there, but it sounds like somethings got a tight spot and sticking perhaps, either on the beam or dampers (Although they're new IIRC?)
Posted 28th Feb 2011 at 22:33
did yopu tighten the damper bolts with the car on the ground?
Posted 28th Feb 2011 at 20:57
iplay
no i did it with the car on stands ... should the bolts be tightened on the ground?
Posted 1st Mar 2011 at 03:33
yup, so there's no tension in the bushes, same as the front bushes on the wishbones Smile
Posted 1st Mar 2011 at 04:04
iplay
Posted 1st Mar 2011 at 16:33
russbez
im confused Unsure
what bushes are you on about?
i had my car up on axel stands, took a rear shock off so i could put a Helicoil in to repair the thread for an ARB bolt
iv just tightened the shock back up when the car was up in the air
shale i just lowered the wheels back onto the ground, loosen the bolt and retighten?
hope this makes sense LOL
My Rallye project thread
Posted 1st Mar 2011 at 16:46
The bushes in the eyelets on the shock absorbers.
Posted 1st Mar 2011 at 17:45
russbez
ahhhhhhhhhhhhh
so there is
ty phil
Posted 1st Mar 2011 at 20:10
davedgti6
I just raise the trailing arm up with a jack until the car comes off the axle stand slightly and then torque up both the bolts Smile
Posted 1st Mar 2011 at 22:18
I just get under and tighten them up while it's on the floor.
Tiny 1.4 rear bumper ftw LOL
Posted 1st Mar 2011 at 22:20
I can do that with my deep sport bumpers on the ZX Big grin
Stock ride height FTW Laugh my ass off
Posted 1st Mar 2011 at 22:58
