Author Subject: rear beam (snapped bolt)
james_gti6
just noticed that the bolt that holds the anti roll bar end plate has sheered off. the car was lowered not so long back. any feedback would be appreciated.
would this be because one side is lowered more than the other.
if i dont see you in the mattress il see you in the spring
Posted 28th Feb 2011 at 05:08
Probably not been torqued properly, as soon as they come loose/stretch they shear from the force.
Posted 28th Feb 2011 at 05:17
ksung17
one of mine snapped resulting in both arms seizing.
Posted 28th Feb 2011 at 05:37
What Phil said. Although I don't know what he's doing on here, he should be off welding up my lower brace.
It's just a standard M6 (I believe? Possibly M8) but certainly metric, get the old one out by whatever means and replace it with a new high-tensile one, 8.8 grade will do you fine.
Then do it up nice and tight Yes
Posted 28th Feb 2011 at 12:42
standard is M8 x 1.25.
Make sure the threrads are good, plenty of locktite and torque wrench.
Posted 28th Feb 2011 at 21:00
james_gti6
cheers guys, will get the bolt out this weekend. and check the ride height
Posted 28th Feb 2011 at 21:13
