Author Subject: Exhaust noise
monkgti
well lads, i fitted a decat to the car a few months back, and it was perfect for a while, sounded great and you wouldnt even notice any sound difference while the car was idleing, but lately the exhaust has developed a kind of metalic vabrating noise at roughly 3,000rpm, and also at idle it makes a vibrating noise that almost sounds as if the exhaust is blowing slightly. Ive located the sound and its coming from the section of the exhaust behind the decat, not the baffler but the pipe around where the center mount is. Now the exhaust is nowhere near any part of the body and all joints are sealed perfectly with no blow and solid thight. All the rubber mounts are perfect also and if i shake the exhause or hit it by hand theres no noise so theres nothing inside thats doing it but if i just press on the exhaust right where the rubber mount is with the car running the noise stops straight away, so i bought a powerflex mount for the center thinking it might solve it but no difference atall. I know its just a stupid little thing but its really annoying, especially when driving around town as it can be heard fairly loud outside Sad
Anyone ever had any problem like this with there exhaust? Would it just be a case of loosening, moving and rejoining the decat joint mabey?
IF YOU CAN READ THIS IM STILL IN 5TH!!!
Posted 23rd Feb 2011 at 05:22
oecken
its a bit strange this, i know that when i put a devil decat on mine, i was advised before from some members that they get a rather annoying resonating sound from around 3k rpm and above, especially on motorways, so i wrapped mine in high temp heat wrap and its a lot quiter than others ive heard. If all the seal are fine, and the mounts made no difference then im at a loss im afraid. but "metalic vibrating noise" does sound similar to the ones ive heard resonating Hmm
Posted 23rd Feb 2011 at 13:45
bennn
Magnex by any chance?
If it is try tapping your center box, if it sounds hollow then all the wadding will have burnt out / been blown out, needs either opening up and rewadding or a new centre section putting in.
I had this on my magnex and it sounded terible so i had a new powerflow centre section welded in. Job done.
Cherry Red 306 HDI
Posted 23rd Feb 2011 at 17:00
monkgti
oecken, yes its the same on mine, it comes into it at about 3,000 rpm just at a certain point and then when the revs go past that the noise goes again or if im stopped and hold the throttle at the certain point in neutral the the noise will stay there until i drop the revs or raise them...
bennn,its a standard exhaust just with a decat bolted in, and ive hit and shook the exhaust to check as you suggested but there is not one sound from it at all, but the noise seems to be coming from just behind the centre box, you know where the rubber mount is just around the bend?
Posted 23rd Feb 2011 at 19:10
jakeypoo
I have exactly the same thing on mine! So changed to a second hand powerflow system, cured it a bit but can still hear it sometimes! I think it may be something to do with cat not being oem an raising and touching the heatshield! Could your decat be doing the same?
Posted 24th Feb 2011 at 01:32
monkgti
no man it doesnt touch anywhere at all... i checked everywhere and its well away from the heat shield all around and even if i gave it a good shake it still doesnt touch!! Whats weird is that as soon as i push on the exhaust where the noise seems to be coming from it stops Crazy
Posted 24th Feb 2011 at 02:24
james_gti6
i have the same problem, i think it is just a resonating noise, i thought the same when i put mine on, i have now heat wrapped my decat, its a little batter but not 100%
if i dont see you in the mattress il see you in the spring
Posted 24th Feb 2011 at 02:42
anderzz
Mine does this too, its bloody annoying because it makes people think my car is crap lol.
I think it eases off a bit when it warms up on mine though.
Posted 24th Feb 2011 at 04:59
monkgti
yeah thats it alright, a resonating noise, it asa if the pipe is vibrating making the noise by itself, not actually touching off anything... yeah exactly what i dislike most about it, gives people another excuse to slag the french car!! LOL
Posted 24th Feb 2011 at 06:26
My Scorpion system used to resonate horribly at 3,000 RPM too, it always did it and I just got used to driving around it if you know what I mean. I did cut open the resonator box and re-pack it with stainess wool and E-Glass. But that was just before I sold it so I never heard it after. I suspect that your perforated tube in the expansion box is cracked, also check the welds in and out of the resonator very carefully as exhaust systems are heavy and unless the tube inlet and outlets are supported with well designed gussets you can get fatigue cracks in a relatively short space of time. Add to that expansion and contraction from exhaust gases and splashes from puddles and cracks can grow very quickly.
Posted 26th Feb 2011 at 21:58
throughlou
I get this on my standard exhaust
WHen starting from cold it rattles loads on idle and at 3000rpm
Once its warmed up i just get it at 3000rpm
Posted 27th Feb 2011 at 02:22
parkerpug
Hi can anyone recommend someone near stoke on trent who might help with mine. It sounds rough as f'k. I had a new cat last year, 'kwik fit' emergency and its never sounded right since. last month one of the spring loaded bolts was found to be loose (which seemed to fix it) but now the noise is back and the bolts aint loose. It sounds like its blowing but no holes can be found!
Posted 28th Jun 2011 at 17:55
All of you with vibrating sounds , check your heat shield that bolts DIRECTLY to the exhaust cam cover, mine created a noise and no one could locate it for ages
Posted 26th Jul 2011 at 05:26
7057sam
A little of topic but has anybody got a decat+standard exhaust to "pop",or is it only when you get stainless steel?
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 26th Jul 2011 at 06:32
mattgti6phase2
The standard silencers are far too choked. Mine chucks out foot long flames Cool Full stainless ftw!
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 27th Jul 2011 at 05:34
swiftyboi006
Flames? I take it this is from alot of heat theough it and good ol thrashing?
Black p3 Love
Posted 12th Aug 2011 at 18:04
pebbles167
Anyone get a vibrating noise at medium to high revs after you have let off the accelerator? I'm hoping to god that its my exhaust and not my gearbox Sad
2005 Peugeot 206 GTI 180
2008 BMW K1200R
Posted 13th Aug 2011 at 04:33
walker_texasranger
Chaps, had this on both of mine, I bet you that its 99% going to be a cheap centre section, these cars don't like them. Had a few Timex mid sections and they all got swapped under warranty because they resonated horribly at 3000 rpm after only a few thousand miles..... sounded like an unwanted Nasal Uncle. The Bosal was better for a while but for complete piece of mind get an OE one (about £120 new) and get it fitted properly, problem solved Wink
Hilux InvincibleX daily
306 No.13 Doh
Posted 21st Sep 2011 at 17:48
