displaying posts 1 to 25 of 30
Author Subject: Urgent: Pressurised Coolant and Mayo Problems
chiefy
Today I thought I'd double check my fluid levels even though the car has been running perfect recently, with no overheating bar the usual getting a bit warm in traffic scenario.
Anyway, I open up my coolant filler cap and it almost bursts out of my hand with pressure although it has not been driven since Monday. First of all, is this normal?! I once asked a friend who has a garage and he says it's a good sign that there are no leaks, however I am pretty sure my heater matrix is leaking as it's giving off quite a coolant mixed with curry smell (As described by others with heater matrix failure in another thread).
Second problem, coolant level is right down the bottom, and what's worse, there are bits of "mayo" in it. So obviously I panic and think the worst, but then after checking the dipstick and oil filler cap, there are no signs of mayo there at all. In fact it looks very clean in those areas still.
Mayo in the oil can be due to condensation, but does mayo in the coolant mean that there is definitely oil in there and something very bad is happening?
Also I have done something that may have been very stupid looking back on it. Basically I poured some coolant into the tank, and to my surprise it took less than 1 litre. So I thought I'd open all the bleed valves, and sure enough there was no coolant coming out of any of them. At which point I remember the car is facing down a hill! As soon as I open the valves I hear the movement of water, and now the rear two valves are dry, the radiator valve has some liquid around it, and the header tank level has risen to almost the top!
What should I do now!?
All help is very much appreciated
Posted 18th Feb 2011 at 17:02
daver6
Head gasket possibly? I've had the Curry smell quite a bit... quite liked it in the end! lol
Get a compression test and/or Hydrocarbon test done, a good indication for water and oil mixing. Draining the oil will show if there's any water in there too.
I make a header tank with a pop bottle with the bottom cut out (local woods are full of these, though probably because kids like smoking tac through them), I wrap the threads in PTFE Tape and lash that into the reservoir. Then block the overflow pipe. THEN you can top up the header and open the bleed valves.
Rad > Thermo > Matrix. Once you get a nice constant stream of water with no air, lock them off and start the car.
Wait until the fans kick in (if they do) and you can open the valves again, same order, one at a time.
Be careful, it'll be HOT!
I don't know if anyone has a tip for the matrix, other than using industrial gauntlets from work, I can't see how you can bleed it whilst hot. The pressure behind the valve was to the point of firing the valve cap off into the abyss if I'd let go.
When I suspected HG, it was due to bubbles in the water whilst I poured fresh oil in (to the engine), but this was a matter of confusion as to many people it didn't sound like a HG problem.
Oh, does your car misfire when started from cold?
Wishbone Polybushes available
Posted 18th Feb 2011 at 23:13
rich_w
It does sound like HG failure to be honest..
As you say, the mayo could be down to condensation, if the oil is OK I think the pressurised cooling system is a bigger issue.
I would do a hydrocarbon test on the coolant - this will let you know if any combustion gases are present in the cooling system.
Any garage should be able to do this for you.
The most common failure mode for HG's on these engines seems to be a breach between a combustion chamber and water jacket, which seems to be the symptoms you describe.
Contact Details:
07732 822546
Posted 19th Feb 2011 at 02:22
vernam616
Might be way off here but it could be your heat exchanger/Oil cooler that has failed and allowed oil into the water
Audi S3 Black Edition
Posted 19th Feb 2011 at 02:59
rich_w
That's unlikely given the oil is OK.
Particularly given the excessive cooling system pressure, which would force water into the oil if the heat exchanger was defective...
Smile
Contact Details:
07732 822546
Posted 19th Feb 2011 at 03:46
I have exactly this issue. Too a tee minus that curry thibg :s
Basically the coolant is slightly pressurised , theres a teeny bit of mayo.
Tbh there has always been the most minuscule amount since i had the car 2 ywars and 26k ago but now the coolant is pressurised also.
If there is hydrocarbon in the coolant, what is the best course of action. Changed hg now? Is that cheaper?
Or just wait until it goes? (Not sure i fancy that, if i use the car im normally in central london or on my way home on a 200 kile trip )
If it makes a difference i changed the oil today and can catagorically say there was 0 mayo in it
Thoughts?
Posted 2nd Jul 2012 at 17:47
Thoughts?
change it now before the engine dies.
Posted 2nd Jul 2012 at 19:17
Completely agree. Yes
Posted 2nd Jul 2012 at 19:45
Thoughts?
Head gasket
Get it done ASAP Thumbs up
Posted 2nd Jul 2012 at 20:06
playboyb
i had a head gasket change on mine and there was no mayo or water in the oil, just the fact it wouldnt start and was bubbles in the coolant, hasnt yours already had the hg done? might be worth checking if you can get another skim off the current head, either way mate get it done before it goes fully, then youll be kicking yourself!
306 1.8 xs moonstone blue-SOLD
306 gti6 supercharged china blue-SOLD
406 coupe D9 3.0 V6-SOLD
Posted 2nd Jul 2012 at 20:27
jord294
Headgasket!
Sort it sooner than later, as consistently pressurised cooling systems have a habit of blowing the heater matrix
Posted 2nd Jul 2012 at 20:37
Right cheers all. I think so playboy, im sure it was mentioned when i bought it but i cant find that anywhere in the history.
How spanked can i expect to be? I assume the belt wouod need to be done to?
Posted 2nd Jul 2012 at 20:44
Also does anyone know of anywhere good to take it either near ish islington / north london
Or in south wales.
This is going to be a bit of a logistical nightmare though really.. Sad
Posted 2nd Jul 2012 at 21:34
teo79
head gasket 100% had it with my mates 6 use it as a chance to port and polish the head maybe add cams
tjones
Posted 2nd Jul 2012 at 23:20
Im afraid to funds barely allow to change the gasket let alone add stuff. Sad
Posted 2nd Jul 2012 at 23:30
teo79
just a thought
tjones
Posted 2nd Jul 2012 at 23:48
Anyone got any garage recommendations?
Im hoping to get this sorted next week.
In which case I would be looking for a garage nearish to north london/ central
Posted 3rd Jul 2012 at 13:01
jord294
welshpug?
Posted 3rd Jul 2012 at 14:29
Not a garage is he? Razz or is he? if he was i didnt know Razz
Posted 3rd Jul 2012 at 14:36
jord294
i just know he's done work in the past for forum members south wales area
Posted 3rd Jul 2012 at 14:44
yup, I did Jord's old white wallye earlier this year, not a garage but I do work like that every now and then.
Posted 3rd Jul 2012 at 14:52
Oh really? Smile Don't suppose you fancy doing a head gasket and cam belt/water pump on a s**t car then do you? Razz
Posted 3rd Jul 2012 at 15:29
Done them before LOL
What's your budget?
done three this year, jimmyrallye's old shagger, thug's black 6, and Jord's wallye that ratboy bought and sold.
Posted 3rd Jul 2012 at 15:42
Bloody hell Razz
My budget is what it cost really, Iv'e been told to expect 700 by a garage?
Are there options though? Like do you mean that there is a cheap option and a proper option? If so I usually go for the proper one Smile
Put it this way, I want the car to last Smile
Posted 3rd Jul 2012 at 16:11
