Author Subject: Rear beam ride height Gurus?
matt evans
Just about to reassemble the rebuilt beam and have managed to secure a dummy shock to help set the ride height.
Im lowering the front on new B8's and new 30mm lower Eibach springs..... so....
Am i right in saying that the standard rear shock mounts are 330mm, and that a 3mm change in ride height is a 2mm difference in shock bolt distances?
so, assuming a 30mm drop on the rear (im fitting VTS torsion bars as well) will be a 310mm distance in bolt centres?
Will the stiffer TB's have any effect on static ride height? Ie will i need to drop it a touch more because its stiffer?
Ive used the search but not found a deffinative answer..
honestly3k wrote:
owain wrote:
Posted 17th Feb 2011 at 14:47
simonjames
Yes 310mm for a 30mm drop
MY EBAY ITEMS
07943066306
Posted 17th Feb 2011 at 14:51
jord294
apart from b8s, you'll want the same height as my 6
so 310mm should be similar to this
but slightly lower with afull tank of fuel Wink
Posted 17th Feb 2011 at 16:41
marksorrento205
When I fitted 21.3 mm torsion bars on the 205, I set it to the std height. It looked like a 4x4 to say the least LOL So I would say yes.
Posted 24th Feb 2011 at 01:07
marksorrento205
I does look nice at that height mate. Just ordered my billies and eibachs Big grin What distance did you set the beam at with the 21mm torsion bars?
Posted 24th Feb 2011 at 01:08
jord294
i think i went for about 308mm
but as said, with a full tank of fuel it does sit lower
so i'd go with 310mm to be safe Wink
Posted 24th Feb 2011 at 17:39
marksorrento205
Cheers matey Smile
Posted 24th Feb 2011 at 18:32
iplay
thread pitch on dummy shock is 1.25mm and 1mm on dummy shock = 3mm ride height with standard torsion bars. 1 turn on dummy shock = 3.75 mm. half a turn 1.875mm.
Posted 28th Feb 2011 at 18:30
322mm on stock torsion bars i've found is around 25mm, 320 around 30mm.
Very hard to be precise with specific lowering distances really what with bushes and manufacturing tolerances, but easy enough to get both sides the same.
Posted 28th Feb 2011 at 20:53
