Author Subject: Oil temperature reading (incorrect?)
flynn_
I've setup an oil temperature gauge for my car, but it only gets to about 50 degrees under normal driving and nearly to 75 when sat idling for a few minutes. If I drive fast it does go up a bit as well, but only a fraction. At first I thought it was a bad earth, but now I've earthed it to a bolt screwed into the chassis and the backlight is also using that earth and it is working fine. I could have sworn when I earthed it to a bolt before with a different wire, it read about 100 degrees which would have been right, however on the earth wire that I am using for the gauge I soldered the wire into the spade plug so it definitely has a connection to it. The other thing is, I am using an 'add a circuit' connector off a switched live from the fuse box, I've got one 15 amp fuse in one slot and nothing in the other, might that have something to do with it?
Posted 15th Feb 2011 at 02:41
100 degrees seems a little warm and 50 seems low, is the guage the right sort to work with the sender?
Posted 15th Feb 2011 at 02:43
i have this same issue with a gauge i had made, driving me mad Blink
Posted 15th Feb 2011 at 02:46
flynn_
Yeah mate, it came with the sender I'm using.
Posted 15th Feb 2011 at 02:57
flynn_
No one cracked this problem successfully then?
Posted 2nd Mar 2011 at 00:47
When you say the backlight is using the same earth, do you mean the gauge is earthed to the same point?
Or the sender itself?
Usually the sender earths through the block, but if can't get a clean connection because of oil/dirty threads you might need to run a copper ring connector under it and earth it to the chassis directly.
Posted 2nd Mar 2011 at 00:52
Where's the sender? Is it a sump plug one or an inline one?
Posted 2nd Mar 2011 at 02:27
