Author Subject: new belt on, locks up !
denwar
fiited new belt the day, twice infact, pinned the head and pinned the crank pulley, remove pins when belts been fitted, it locks up when i try to rotate eng, am i correct to think that the crank pulleys can slip on these, so the result would be timing incorect ?
denwar
Posted 9th Feb 2011 at 02:05
yup.
Posted 9th Feb 2011 at 02:07
denwar
are these t.d.c at midbore ?
denwar
Posted 9th Feb 2011 at 02:15
Ouch.
Posted 9th Feb 2011 at 02:19
no, TDC is always at TDC.
however yes they do lock at mid bore, not TDC.
Posted 9th Feb 2011 at 02:20
denwar
can the flywheel be pinned from behind the starter to get timing tits on ?
denwar
Posted 9th Feb 2011 at 02:24
no, that's only the XUD and DW8.
jeffers Forum Admin
Doh! Doh Dig deep time! Sad
Team Running Engine again!
Team Negative Camber!
Posted 9th Feb 2011 at 02:34
pugjim
not simples Ninja
Posted 9th Feb 2011 at 02:53
Just abit!LOL
Thought it was common knowledgeNinja
Mine that has slipped slightly Shock
Posted 10th Feb 2011 at 04:36
smegal
You'll be needing some new valves.
Ex SC-6
Now in a Megane R26
Posted 10th Feb 2011 at 07:15
tvrfan007
Whistle
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 11th Feb 2011 at 12:40
rallyeash
Doh! Doh
surely all the timing holes couldn't of been lined up?
head off new valves needed then!
309 3dr K20 Type R
Posted 11th Feb 2011 at 13:32
rallyeash wrote:
Doh! Doh
Can't have pinned them before removing old belt?
Then moved the crank to time it up with belt off?
Unsure
Posted 11th Feb 2011 at 22:28
denwar
i didnt start the car guys, it turned out it was just the bottomk pulley that had slipped, i just robbed one from another gti6 in the garage, fired the 3 pins into her adjusted the verniers and nipped up the belt, runs quiete as a mouse, gave it new water pump at same time, new drive belt and a brand new auto tensioner, runnung very well considering its rolling onto 150k, and i only paid 500 for the car , short mot and tax though.
denwar
Posted 12th Feb 2011 at 22:49
720puggti
I don't understand why people get into such a fuss over the timing of the engine.
As long as the engine was running properly prior to changing the belt, pinning the cams into place is all that's really required, as the crank is timed as long as the cams are.
You then whip off the crank pulley mark the crank against the block with some tipex and remove the belt. Replace the belt and gubbins and turn it over with the pulley on, remove pulley again make sure cams are pinned and the tip ex mark should line up.
But those are just my thoughts... I guess people feel confident with an aligned pulley.
BTW Denwar, the first time I rebuilt my engine it only began tapping after a while. If yours doesn't tap I'd consider you extremely lucky as it doesn't take a lot to bend these valves; even a fraction. I hope what happened to me doens't happen to you...
Deepak Gohil
Posted 12th Feb 2011 at 22:58
denwar
it wasa fairly new pulley i used to time mine, i usualy just take out plug 1 and 2 and use 2 cable ties to set midbore and pin the head.
denwar
Posted 12th Feb 2011 at 23:12
Totally agree, although I guess if you don't do it very often people would be more comfortable with the correct alignment of the pulley. Smile
Posted 12th Feb 2011 at 23:19
davedgti6
Tbh I prefer to use the timing pins and lock the cams together with the special tool when loosening and tightening the cam pulley bolts, it is the right way after all,
There is nothing wrong with doing it the way suggested on here if you are competent enough I suppose although if not it is the cause of many tapping engines I fear,
The Autodata Faq on here is the best guide I think, also I don't like the method of lining the woodruff key with the 9 o' clock bolt (although it is a good visual check to make sure you are in the ballpark) as I think it's not accurate enough, I have seen a cambelt done this way and then checked with the timing pins and the cam pins did not go in (but were very close),
Just my opinion of course and others may say near enough is good enough but I prefer to be 100% spot on Smile
Posted 13th Feb 2011 at 00:41
