Author Subject: eccentric top mount nuts
rallyeash
although on my 205 but the 306 compbrake top mounts are the same design. issue is the step down nut on the top bolting onto the strut doesn't go down far enough, only use's half the nut and doesn't look very safe.
i remember reading something on here before how people overcame it but a search didnt bring anything up.
thanks Ash
309 3dr K20 Type R
Posted 7th Feb 2011 at 02:33
pugheaven
You need to get get the top of the shock turned down so it sits higher up in the mount/bearing!
Posted 7th Feb 2011 at 02:30
rallyeash
yeah i had a funny feeling its what was needed, so will need to turn it down and run a dye down to increase the thread length.Sad
309 3dr K20 Type R
Posted 7th Feb 2011 at 02:32
mabgti
NV motors
Turn down the sleeve nut a little..
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 7th Feb 2011 at 04:38
pugheaven
No need to run a die down it, the extra bit of shock going up in to the bearing will give you the extra thread on top!
Posted 7th Feb 2011 at 23:01
rallyeash
for the short term i think i will turn the nuts down as got a trackday in 2 weeks and im not going to have my car back until this weekend at the earliest and will need some testing before then. can't afford not to the shocks on the car.
309 3dr K20 Type R
Posted 7th Feb 2011 at 23:12
devere
With the Peugeot sport bilsteins, there is an insert with a longer thread at the top, designed for use with the adjustable mounts. There is also the one with the standard length thread. Im guessing that the other manufacturers just dont design with those top mounts in mind!
Posted 7th Feb 2011 at 23:21
Some rods have a removable collar that can be used or not dependant on which design of topmount bearing is fitted at the time. Most rods however don't have this useful feature.
Posted 11th Feb 2011 at 05:42
velar
did you ever sort this out.
I have just had the same issue and have threaded the inside of a standard tophat spacer, and used a very thin half nut to lock it all together.
Posted 14th May 2011 at 02:17
