Author Subject: gearbox syncro
mattgti6phase2
evening all
ok, for some time now my 2nd gear syncro has become weak so i have adapted my driving style for the change from 1st to 2nd.
since doing this it has been fine with the occasional small crunch when i have changed at too higher revs.
so yesterday me and a new aquired friend carried out a clutch change. f*ck me was the old clutch fudged!! which i believe to be the original one, anyway the clutch is in and WOW its so smooth Smile
basically what i did i believe was slightly lazy and maybe stupid of me!! i drained the gear oil out and used it again once the new clutch was in and now the 2nd gear syncro seems a hundred times worse.
however i believe the reasoning behind the 2nd gear syncro now being worse is due to me using wynns gear treatment which basically thickens up the oil!
one tube treats 2 litres but i have put 2 tubes in! OOPS Dry so would i be right in thinking that now the gear oil is much too thick thus for hindering the syncro further?
thanks in advance
Matt
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 31st Jan 2011 at 01:20
Anyone who's ever had anything but clean, pure, standard Pug gearbox oil has had problems.
Empty it out and fill it with normal Pug stuff, will only make it better Yes
Posted 1st Feb 2011 at 20:22
+1 standard 75w80 Peugeot gearbox oil is the only way to go...Yes
Posted 6th Feb 2011 at 23:06
mattgti6phase2
i had a weak sycro so was trying to prolong
its life as im have the 2nd gear sycro rebuilt Smile
i thought pug recommend 75 90??
5 x a 306 owner!
Posted 6th Feb 2011 at 23:08
not for the BE and MA boxes, its the ML that used 75w90.
they specify, not recommend Wink
Posted 6th Feb 2011 at 23:17
Thickened oil with friction modifiers (which is exactly what your additive has just done), is just about the worse thing for a synchro anyway.
Especially ones as fussy as the Pug ones.
Posted 6th Feb 2011 at 23:32
mattgti6phase2
much difference then between 75/80 and 75/90?
due to what pug told me im currently using 75/90 Dry
5 x a 306 owner!
Posted 6th Feb 2011 at 23:33
75w is quite a wide band for rating, so you'll find that most 75w90's are actually a lot thicker than 75w80's both hot and cold.
The difference between them can easily be 50% both hot and cold, it could be twice as thick when warm depending on the brands.
Posted 6th Feb 2011 at 23:42
mattgti6phase2
The difference between them can easily be 50% both hot and cold.
shit! thats no bloody good then! Shock
although since being rid of that shite treatment the box is a million times better!!
5 x a 306 owner!
Posted 6th Feb 2011 at 23:43
smegal
How come you didn't change the box when it was off?
Ex SC-6
Now in a Megane R26
Posted 7th Feb 2011 at 01:21
mattgti6phase2
As said above at the beginning of this thread pure laziness mate.
The synchro was damaged before I used the treatment. and that was due to my gear selector popping off as I was going into 2nd gear and ever since then if you take it past 6 k and throw it into 2nd quickly you get a small crunch!
I have a quote to replace 1st and 2nd gear mesh which is £140 + vat I think that's a fair price??? Plus you get warranty with it. The reason fir 1st gear mesh being done aswell is due to 1st and 2nd sharing the same hub so best to replace both.
I use the word hub loosely as I can't quite remember how the refurb company explained to me Wink
I could get a 2nd hand box but you never know what condition its in until it's been put in!
5 x a 306 owner!
Posted 7th Feb 2011 at 04:14
Its usually 3rd that gets mashed though and £140 would get you at least 2x second hand boxes and oil.
As the box has been off i'd keep an eye on the shaft oil seals too. They should be ok, but sometimes don't like being disturbed.
Posted 8th Feb 2011 at 20:06
Rich E Forum Admin
They are different problems though. The issue with third gear is the teeth on the gearset shearing.
The first to second crunch is a selection / synchroniser hub issue. It could be a worn hub but I'm sure Miles has said before that it's usually caused by a worn selector spring.
I'm unsure what the refurb place means when they talk about replacing the mesh though, as there aren't any meshes. Unless they mean the gearsets but there'd be no reason to replace those.
£140 + VAT sounds too cheap for replacing the hub too, unless it's a second hand hub, as it's ~£160 from Peugeot for the part.
Posted 8th Feb 2011 at 20:22
mattgti6phase2
i have heard this to rich and it makes sense to me.
as for the refurb company they said it would be a hub change which contains both 1st and 2nd gear?
the compnany is called ATE is it worth having the work done there or do you think i would benfit more for slinging another 2nd hand box in?
many thanks Smile
5 x a 306 owner!
Posted 10th Feb 2011 at 05:05
miles
The hub does not contain 1&2 only the Synrco rings, the gears are seperate,
Normally as Rich has said a spring clip on the hub snaps, Handy like me if you have loads spare or it's a new hub. so the differance between 50p and 150 ish.
www.pugracing.com
Posted 11th Feb 2011 at 00:49
mattgti6phase2
ok just bare with me as i kno very little about the inner workings of a gearbox Whistle
so as you have so many i could purchase one from you?
do i tell this refurb company that they only need replace this spring you speak of?
will the crunching of 2nd gear have damaged anything else at all?
many thanks matt
5 x a 306 owner!
Posted 11th Feb 2011 at 02:38
where in the country do you abuse Tarmac? if you're in the south ish I'd see what Miles can do for you Thumbs up
Posted 11th Feb 2011 at 03:00
mattgti6phase2
LOL Buckinghamshire mate where's miles based not heard of ringwood?
5 x a 306 owner!
Posted 11th Feb 2011 at 15:40
miles
LOL, you don;t get out much, It's on the edge of the New Forest, about 20 mins from Southampton
www.pugracing.com
Posted 12th Feb 2011 at 01:29
mattgti6phase2
I'm just terrible at remembering where places are LOL however that is savage mileage from my neck of the woods Wink
5 x a 306 owner!
Posted 12th Feb 2011 at 03:44
miles
Bucks is only 5 mins up the road, I used to travel to East Anglia and back in a day when I was working for Anglian Water
www.pugracing.com
Posted 14th Feb 2011 at 02:18
