Is this just a case of the slides wore on the calipers or is it a common thing with these? ive done a search but found nothing...
IF YOU CAN READ THIS IM STILL IN 5TH!!!
| Author | Subject: Rattleing Calipers |
monkgti
Regular Location: New Ross Registered: 31 Jul 2009 Posts: 343 Status: Offline |
well folks, has anyone experienced any noise or rattleing from their front brake calipers? i have this noise a good while now when driving on rough ground, at first i thought it was drop links or drop links so ive changed all them and wishbone bushes and tie rods but its still the exact same, and ive just noticed the other day that if i lightly press the brake pedal when on the rough road the noise seems to stop! Ive checked everything on the calipers and its all thight and theres only new discs and pads gone on few months back. Its not a really loud noise but it is definitly noticible and one or 2 passengers have asked what it was aswell as they heard it too..Is this just a case of the slides wore on the calipers or is it a common thing with these? ive done a search but found nothing... ________________________________________ IF YOU CAN READ THIS IM STILL IN 5TH!!! |
fozzy_255
Senior User Location: portsmouth/Folkestone Registered: 30 Dec 2007 Posts: 677 Status: Offline |
If you are sure its the callipers, can't you just take the pads out and put it all back together just to make sure it hasnt been done wrong? |
mr west
Senior User Location: herts Registered: 13 Sep 2010 Posts: 742 Status: Offline |
i had this on the rear calipers on an s16 i had.the noise went when i pressed the brakes i belive it was a split pin fault(pads ratterling in the calipers as the shim that sits under them was not tight) i know it went when i took out the pads and copper slippes the back of them and put new pins in anyway. hope this helps ________________________________________ white rallyecherry dead rallye s16 |
monkgti
well its been in the car since i got it but got slightly worse, but since ive got the car i changed the pads and evereything was put back proper but the noise was still there thats why i didnt think it was the calipers until i changed the droplinks etc and found it was still there________________________________________ IF YOU CAN READ THIS IM STILL IN 5TH!!! |
SteviePut
Seasoned Pro Location: Down south Registered: 20 Oct 2005 Posts: 13,637 Status: Offline |
Check the driveshaft locking cap. It's the bit that the split pin goes through ![]() ________________________________________ My old man wrote me a letter from prison once. It said if you don't want to end up in here, stay away from crime, women and drugs. Trouble is, that don't leave you much else to do, does it? |
Rich E
Broken ABS sensor cap?________________________________________ Rich |
monkgti
no, checked all them lads, cant find anything loose atall when i jack the car up or anything that makes the same noise, only time i can hear it is when im driving on rough road, im only assuming its the calipers aswell because it goes when i press the brake pedal but im not 100%sure its them either...________________________________________ IF YOU CAN READ THIS IM STILL IN 5TH!!! |
flymo
Newbie Location: London Registered: 24 Jan 2011 Posts: 2 Status: Offline |
anti-rattle clips missing from the pads? |
Fit V6 Brembos, the squeal will drown out all other noises ensuring worry free motoring for you and your passenger ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
SteviePut
daveyboy wrote: Fit V6 Brembos, the squeal will drown out all other noises ensuring worry free motoring for you and your passenger Or wilwoods ![]() ________________________________________ My old man wrote me a letter from prison once. It said if you don't want to end up in here, stay away from crime, women and drugs. Trouble is, that don't leave you much else to do, does it? |
mr west
daveyboy wrote: Fit V6 Brembos, the squeal will drown out all other noises ensuring worry free motoring for you and your passenger lol if you cant cure it modifie it ________________________________________ white rallyecherry dead rallye s16 |
rich-6
Seasoned Pro Location: Bottoming out! Registered: 06 May 2007 Posts: 5,306 Status: Offline |
flymo wrote: anti-rattle clips missing from the pads? This mans on the money, The springs are missing ________________________________________ ![]() RIP Pete Sims |
monkgti
or could invest in a louder exhaust to drown out every rattle and noise from the car, she be like new then!!!well are the springs on them just the ones that are made onto the pads? Because there all there ________________________________________ IF YOU CAN READ THIS IM STILL IN 5TH!!! |
flymo
there should be some removable clip things that hold the pads in place, they attach into the slots on the outer edge of the pad and they kinda look like opened up paper clips... (they're not built into the pads tho)that was the cause of my rattle anyways... |
monkgti
is that not the rear ones you mean lad? i know the rears have a clip on the back of each pad that does actually look like an opened paper clip... ________________________________________ IF YOU CAN READ THIS IM STILL IN 5TH!!! |
monkgti
only got a chance to look at the brakes today, the springs are attached to the back of the pads and are present on all 4, it seems the caliper is just loose enough to rattle on rough ground, the bolts and all are thight its only when tipping the brake pedal that they thightin enough to stop making noise, is it just somthing ill have to put up with or could it be the slides wore or somthing??________________________________________ IF YOU CAN READ THIS IM STILL IN 5TH!!! |
are the springs in the correct place? take a pic ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
my 307 ones do the same tbh. check the slider bolts are tight.________________________________________ - Bespoke rollcages/additions/adjustments. Half cages right up to complete custom spaceframes - MSA/FIA spec, CDS, ROPT, T45, etc - PM meEmail me! Custom-made polybushes available - need an odd size or fitment? - anything from batch work to one-off pieces. |
monkgti
yep, the springs are fitted proper against the caliper, but will get a pic of them tomorrow!checked the slider bolts aswell and all thight ________________________________________ IF YOU CAN READ THIS IM STILL IN 5TH!!! |
monkgti
just got some pics now, the only place i can feel play is in the 2 slide pins, when i hold the caliper on the inside around the brake hose connection and move it, theres the slightest looseness in the pins![]() ![]() ________________________________________ IF YOU CAN READ THIS IM STILL IN 5TH!!! |
monkgti
bumpy________________________________________ IF YOU CAN READ THIS IM STILL IN 5TH!!! |
stepup
Junior User Location: Basingstoke Registered: 02 Jul 2008 Posts: 55 Status: Offline |
have you tried re-packing the sliders with more grease?________________________________________ owain wrote: Twisties are for those with balls, top speed is for those with tiny little penises. SCIENTIFIC FACT. |
Rich E
monkgti wrote: bumpy Not entirely sure what else you want from us... Only you are in a position to be able to get to the bottom of this! Time to roll your sleeves up and get dirty! ![]() ________________________________________ Rich |
